Author Topic: USB device driver corrupts often in my cab  (Read 876 times)
Dreamwriter
  • Last login:August 28, 2010, 04:33:09 pm
  • Sleep is for the weak!
    • Games of Yore
« on: September 22, 2006, 01:39:49 am »
Hey,
I've got this really annoying problem in my cab, one of my USB devices every now and then (actually fairly often) isn't working when I boot up.  The reason is its driver gets corrupted; I can fix the problem by uninstalling the device in device manager and then scanning for new hardware - it finds the hardware, installs the driver and starts working fine.  Unfortunately, to do all this requires a keyboard.
Do you think the problem could be the USB device or its driver?  Or something else?  I can't finish my nice little arcade machine with this problem occuring.
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
Re: USB device driver corrupts often in my cab
« Reply #1 on: September 22, 2006, 01:50:39 am »
man..I haven't seen anything like what I'm about to suggest since like..windows 98, but since you didn't specify what OS you're using...maybe it'll be helpful...
is the USB bus using the same system resources (IRQ's or whatever) as anything else?  come to think of it...mbye USB doesn't even use that kind of stuff?
but I remember in the old days you could get some stuff to work when it was first detected but then after a reboot it would go wonky on on you.
I dunno man..I'm just trying to help.   :dizzy:
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
Dreamwriter
    • Games of Yore
« Reply #2 on: September 22, 2006, 02:17:52 am »
I guess I should mention the OS, huh? :P  Windows XP SP2.
NightGod
« Reply #3 on: September 22, 2006, 03:19:28 am »
What's the device?
londonbabe
  • Last login:June 06, 2007, 09:24:45 am
« Reply #4 on: September 22, 2006, 04:03:57 pm »
I've come across this before with network cards and things. It's often fixed by completely removing the drivers, then installing them from whatever factory installer (download or cd) you have *before* plugging in the device again.
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« Reply #5 on: September 22, 2006, 04:25:25 pm »
Every once in a blue moon, my I-pac4 would do that, the only fix Andy from Ultimarc says is just keep doing what you doing.
Sorry!
daywane
  • Last login:Today at 03:54:32 pm
  • GRRRR!
« Reply #6 on: September 22, 2006, 05:29:42 pm »
is the device on a hub? or mother board? PCI usb hub??
what is the device.
have you tried the device on another PC?
Was the driver XP compatable??? I have a flash card reader hat XP don't like.
I am leaning towards XP compatable problem off the top off my head and what little we have to go on.
the more info you give us ... the better we can help.
Not nagging you,  just telling the facts  :cheers:
NightGod
« Reply #7 on: September 22, 2006, 11:39:58 pm »
Could also be a flaky USB port-have you tried using another one? My GPS on my laptop does that sometimes if I plug it into a certain port-18 months of bouncing around in a pickup has taken its toll...
