Author Topic: Help requested: C++ member function pointers  (Read 1352 times)
Buddabing
« on: September 19, 2006, 10:14:13 am »
Hello,
The following code gives me a compiler error: "Cannot convert int(ExampleClass::*)() to int(*)() in assignment:
Code: [Select]
#include <stdio.h>
class ExampleClass
   public:
   int (*member)(void);
   int foo(void)
      return 1;
   int bar(void)
      return 2;
   void SetFoo(void)
      member=&ExampleClass::foo; // <----------------error here
   void SetBar(void)
      member=&ExampleClass::bar; // <----------------error here
   int CallMember(void)
      return (*member)();
main(int argc, char **argv)
   ExampleClass ex;
   int result;
   ex.SetFoo();
   printf("result from SetFoo=%d\n",ex.CallMember());
   ex.SetBar();
   printf("result from SetBar=%d\n",ex.CallMember());
   return 0;
Any help correcting the syntax would be appreciated.
TIA,
Buddabing
Please read the wiki!
Spartan
  • Last login:December 02, 2009, 07:09:38 pm
  • I like stuff!
    • The Municade
Re: Help requested: C++ member function pointers
« Reply #1 on: September 19, 2006, 10:42:33 am »
Make foo and bar static, and pass in the instance of 'ex' as an argument.
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: September 19, 2006, 10:46:36 am »
class ExampleClass
   public:
   static int foo(void)
      return 1;
   static int bar(void)
      return 2;
   void SetFoo(void)
   void SetBar(void)
      member=(&ExampleClass::bar);
      return (*member)();
It compiles under VC++
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
« Reply #3 on: September 19, 2006, 10:51:58 am »
The reason "static" needed is because member function pointers cannot be dereferenced without an associated object.   For each member function a "this" pointer is passed implicitly, even though it is not in the function prototype.
Check out this for a little more info.
Buddabing
« Reply #4 on: September 19, 2006, 11:33:18 am »
That worked, but I need to be able to access other members of the class from within the static function:
Code: [Select]
#include <stdio.h>
class ExampleClass
   public:
   int (*member_fn)(void);
   int member_int;
   static int foo(void);
   static int bar(void);
   void SetFoo(void);
   void SetBar(void);
   int CallMember(void);
int ExampleClass::foo(void)
   member_int=1; //<---------------error
   return 1;
int ExampleClass::bar(void)
   member_int=2; //<---------------error
   return 2;
void ExampleClass::SetFoo(void)
   member_fn=&ExampleClass::foo;
void ExampleClass::SetBar(void)
   member_fn=&ExampleClass::bar;
int ExampleClass::CallMember(void)
   return (*member_fn)();
   ExampleClass ex;
   int result;
   ex.SetFoo();
   printf("result from SetFoo=%d, member_int=%d\n",
      ex.CallMember(),ex.member_int);
   ex.SetBar();
   printf("result from SetBar=%d, member_int=%d\n",
   return 0;
The error when this is compiled is "Invalid use of member 'ExampleClass::member_int' in static member function".
youki
    • Atomic Front End
« Reply #5 on: September 19, 2006, 11:41:02 am »
declare the member as static :
static int member_int;
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #6 on: September 19, 2006, 11:43:09 am »
member_int isn't declared static, so accessing it without instantiating ExampleClass won't work.
screaming
  • Registered lUser
« Reply #7 on: September 19, 2006, 11:45:24 am »
Out of curiosity, why are you doing this?
Code: [Select]
void SetFoo(void)
  Since this is the part that's causing you all this headache, are you sure there's no other way to do it?
max8061
  • Last login:April 18, 2007, 10:31:02 am
  • Aroo!
« Reply #8 on: September 19, 2006, 11:49:18 am »
Free homework help on BYOAC?  :laugh2:
Buddabing
« Reply #9 on: September 19, 2006, 11:57:17 am »
Declaring member_int as static gives me linkage errors: "undefined reference to ExampleClass::member_int".
There are always alternate ways of doing this kind of thing. I could make member_int a global variable, or a static external to the class, or I could use a construct such as:
enum
   FOO,
   BAR
switch (state)
   case FOO:
      return foo();
   break;
   case BAR:
      return bar();
   break;
But that's not very elegant.
It is not strictly necessary to use the function pointers like I am doing. But that's what I want to do.
Spartan
  • I like stuff!
    • The Municade
« Reply #10 on: September 19, 2006, 12:29:45 pm »
See my first reply -- make the member functions static, then pass in the ex as an argument....
screaming
  • Registered lUser
« Reply #11 on: September 19, 2006, 12:34:56 pm »
What if you have 2 classes?
Code: [Select]
#include <stdio.h>
// CLASS: ExampleFuncs
class ExampleFuncs
    public:
int ExampleFuncs::foo(void)
  return 1;
int ExampleFuncs::bar(void)
   return 2;
class ExampleClass
   public:
   int member_int;
   int foo(void);
   int bar(void);
   void SetFoo(void);
   void SetBar(void);
   member_int=ExampleFuncs::foo();
   member_fn = &ExampleFuncs::foo;
   member_int=ExampleFuncs::bar();
   member_fn=&ExampleFuncs::bar;
   ExampleClass ex;
   int result;
   ex.SetFoo();
   ex.SetBar();
   return 0;
It compiles on Linux.....
steveb@freda ~/budda $ gcc -lstdc++ -o test main.cpp
steveb@freda ~/budda $ ./test
result from SetFoo=1, member_int=1
result from SetBar=2, member_int=2
Buddabing
« Reply #12 on: September 19, 2006, 12:41:18 pm »
That won't work because foo() and bar() need to access member_int directly.
Spartan
  • I like stuff!
    • The Municade
« Reply #13 on: September 19, 2006, 01:01:58 pm »
I keep telling you -- pass in ex as an argument!
Code: [Select]
#include <stdio.h>
class ExampleClass
   public:
   int (*member)(ExampleClass e);
   static int foo(ExampleClass e)
      return 1;
   static int bar(ExampleClass e)
      return 2;
   void SetFoo(void)
   void SetBar(void)
   int CallMember(ExampleClass e)
      return (*member)(e);
int main(int argc, char **argv)
   ExampleClass ex;
   int result;
   ex.SetFoo();
   printf("result from SetFoo=%d\n",ex.CallMember(ex));
   ex.SetBar();
   printf("result from SetBar=%d\n",ex.CallMember(ex));
   return 0;
Buddabing
« Reply #14 on: September 19, 2006, 01:56:56 pm »
Okay, this works, like Spartan said, pass a pointer to the class as a parameter to any function which can be assigned to a function pointer, then members of the class can be accessed from the statically declared members.
Code: [Select]
#include <stdio.h>
class ExampleClass
   public:
   int (*member_fn)(ExampleClass *);
   int member_int;
   static int foo(ExampleClass *);
   static int bar(ExampleClass *);
   void SetFoo(void);
   void SetBar(void);
   int CallMember(ExampleClass *);
int ExampleClass::foo(ExampleClass *e)
   e->member_int=1;
   return 1;
int ExampleClass::bar(ExampleClass *e)
   e->member_int=2;
   return 2;
int ExampleClass::CallMember(ExampleClass *e)
   return (*member_fn)(e);
   ExampleClass ex;
   int result;
   ex.SetFoo();
      ex.CallMember(&ex),ex.member_int);
   ex.SetBar();
   return 0;
Thanks all!
Spartan
  • I like stuff!
    • The Municade
« Reply #15 on: September 19, 2006, 04:29:35 pm »
You're welcome ;)
screaming
  • Registered lUser
« Reply #16 on: September 19, 2006, 04:49:39 pm »
what was he supposed to be passing as a what?
