Author Topic: Any Fraggal's boot cd alternative ? Or try to solve my sound problem !  (Read 1256 times)
ddrmanxbxfr
  • Last login:November 04, 2008, 06:06:05 pm
Hehe trying to build an mame pc for a friend and he gived me an old Amd k6-2 400 mhz with 136 mo of ram's 6 gig of hd and sound blaster pci 64
So is there any other alternative avaible ? Like dos is lightweight
I found an old version of fraggal's boot cd but sound's is not working  :-[ (SBLIVE driver..)
Or an other alternative like i said.. I knew that omnicade was dead so on...  :-[
Ill post my sound error as soon as i can.
ddrmanxbxfr
Re: Any Fraggal's boot cd alternative ? Or try to solve my sound problem !
« Reply #1 on: September 18, 2006, 05:49:56 pm »
Well with sblive driver i get
Pci Device Detect Failed; Device not found.
spacies
« Reply #2 on: September 18, 2006, 05:56:03 pm »
Great Cd that,
but the sound issues suck and trying to resolve them sometimes takes forever.
There is KnoppixMame and Advanced CD.
Give them a try if you can't sort out Fraggals CD.
Good luck!
ddrmanxbxfr
« Reply #3 on: September 18, 2006, 06:06:28 pm »
Ok well I tried advanceCD and a bit too heavy to play some games that would work in dos..
spacies
« Reply #4 on: September 18, 2006, 06:53:51 pm »
Try Knoppix.
It's a 'live' OS.
Means you can run without even having a HDD cos everything is installed on the CD. You can even install it on a flash device which you plug into any PC and reboot and it becomes an instant arcade machine, well sorta.
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
« Reply #5 on: September 18, 2006, 07:21:51 pm »
What is the model number of your souncard? (example: CT4790)  It might not work in pure Dos mode.
This site (http://www.mameworld.net/dosmame/compatibility.php) may help.  There is a list of common soundcard issues halfway down.
ddrmanxbxfr
« Reply #6 on: September 19, 2006, 08:30:03 am »
Supposed to work she's on the list
But once i got the sound drivers it's now mame that he is freezing   >:(
« Reply #7 on: December 23, 2008, 09:54:08 am »
Sounds like you might have hardware problems.  Fraggal's boot CD works well when you have supported hardware.  Install the most basic configuration you can get away with to minimize variables.
fa001
  • Last login:November 14, 2023, 11:17:08 am
« Reply #8 on: December 23, 2008, 11:19:59 am »
