| Main > Main Forum |
| PC Power supply Hacking |
| << < (2/2) |
| quarterback:
--- Quote from: sealslayer on September 17, 2006, 10:42:47 am ---Damn, I've tried this now on two power supplys and nothing happens, I hope I'm shorting the correct two, theres a clip that fits into the mobo between 15 and 16 is this correct? --- End quote --- If it's not working, I don't think you're shorting the correct two |
| quarterback:
Is this info in the wiki? Seems like it should be since it's a pretty common thing to do. |
| sealslayer:
gahh, the image I looked at showed 15 and 16 on the otherside of the clip, I was shorting two black wires, lol going to give it another try now, thanks again guys ;D |
| quarterback:
--- Quote from: sealslayer on September 17, 2006, 02:59:35 pm ---gahh, the image I looked at showed 15 and 16 on the otherside of the clip, I was shorting two black wires, lol going to give it another try now, thanks again guys ;D --- End quote --- There's definitely an image out there that makes it unclear if you're looking AT then end of the plug or looking at it from the WIRE side of things. When I did this (multiple times) I ended up Googling around for a good pic so I could be sure I didn't screw anything up, which is how I found that particular photo. Good luck |
| sealslayer:
:applaud: Great it works !!, another niggling question at the back of mind gone. Thanks again :applaud: |
| Navigation |
| Message Index |
| Previous page |
