Main > Main Forum
SlikStik Tornado Spinner versus Oscar Spinners
Pages: << < (3/5) > >>
SirPoonga:
I can tell you the obvious differences which might help someone into choosing one over the other.
SlikStik: small footprint, deep installation.  Good for a CP with limited room.  If your cocktail CP is deep enough this would be a good choice.
Oscar: slightly larger footprint  witha  shallower installation.  This is great if you don't want a deep cp.
Deep:  for clarification I am refering to the depth under the cp the spinner takes.
Siris:
I don't think that's quite accurate, The Tornado spinner is almost the exact depth as a standard Happ joystick base.
About 2 1/2"
SirPoonga:
I didn't compare to joysticks, just to each other, how can it not be accurate?
Siris:
Well unless your CP is going to just have a spinner and buttons then depth isn't a factor!
SirPoonga:
Depth is a factor, even with a joystick.
It shallow spinner will provide a little more room to get hands in an around when wiring or maintaining.
Go to full version
