Author Topic: Confused about rom versions / MAME versions - gauntlet  (Read 3304 times)
MartyNg
  • Last login:April 26, 2014, 11:37:48 am
« on: August 28, 2006, 09:23:01 pm »
So I'm running fastmame .71, and I've tried about 15 different versions of gauntlet, none of which work. I always get "required files are missing. The game cannot be run."  How can I find what I'm doing wrong? All of my other games seem to work fine on this version of MAME
« Last Edit: August 28, 2006, 09:27:04 pm by MartyNg »
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 02:20:28 pm
Re: Confused about rom versions / MAME versions - gauntlet
« Reply #1 on: August 28, 2006, 10:02:19 pm »
as MAME changes, the ROMS for that version  may also change. For instance, you might have DOWNLOADED GAULET from a NEWER version of MAME and you want to use it in an older one. Maybe that ROM that you are now missing has been replace/deleted/changed/remove/etc...
So what you need to do is to find those missing files for that PArticular version of MAME you want to use ( it probably quicker if you just use the NEW VER of MAME).
« Last Edit: August 28, 2006, 10:04:07 pm by Thenasty »
Free VGA Breakout Cable
MartyNg
« Reply #2 on: August 28, 2006, 10:10:28 pm »
Unfortunately, I have a slower system, that probably won't cooperate with newer versions of mame. Perhaps I can set up one of the front ends to use multiple versions of mame though as gauntlet probably doesn't suck a lot of CPU through the newer versions of mame. Thanks for the pointer!
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #3 on: August 29, 2006, 08:07:57 am »
clrmamepro..........use it and it will help you. It has the solution! :cheers:
MartyNg
« Reply #4 on: August 29, 2006, 08:10:56 am »
I actually tried that at one point but was having problems. Do I want to use the .dat file for the version of MAME that I am running, or for the version of the roms I have?
NightGod
« Reply #5 on: August 29, 2006, 10:13:41 am »
Use the DAT from the version of MAME you are running.
  • Last login:March 21, 2024, 08:20:28 am
« Reply #6 on: August 29, 2006, 08:09:54 pm »
I've been having the same problems today, clrmame told me that I didn't have the right romset for gauntlet.
