Author Topic: Steering Wheels and more --selling out quick!  (Read 1427 times)
1UP
  • Token Junkie
    • 1UPArcade
« on: August 28, 2006, 02:22:19 am »
Clearing out some overstocked inventory, hopefully you will find something useful.  Most items listed have only been used once for testing, some have never been used or even removed from packaging.  I will accept Paypal, or you can mail a cashiers check or money order (US Priority Mail is recommended).  Orders will ship once payment is received.
First up, I have TWO M7VIG 400 Motherboard Combos, with AMD Athlon Mobile 2200+ CPU INCLUDED.  These have never been used, in mint factory condition.  I use an identical Mobo combo in my main PC.
SOLD OUT
   * General Features:
    * AMD Athlon Mobile 2200+ Socket A CPU INCLUDED
    * VIA KM266 Pro+ VT8235 chipset
    * Socket A
    * microATX form factor
    * 200/266/333 MHz system interface speed
    * Supports up to 2.0 GB DDR266/333/400 SDRAM
    * Two (2) UDMA/33/66/100/133 IDE controllers
    * One (1) floppy controller
    * S3 UniChrome Pro 2D/3D Graphics
    * 64 MB Shared Memory
    * C-Media CMI9761A 6-Channel AC'97 CODEC
    * VIA VT6103 ethernet controller
    * Expansion Slots:
    * One (1) 4x AGP slot
    * Three (3) PCI slots
    * One (1) CNR slot
    * Two (2) 184-pin DIMM slots
    * I/O Ports:
    * Two (2) PS/2 ports
    * One (1) 9-pin Serial port
    * One (1) Parallel port
    * One (1) 15-pin VGA port
    * Two (2) USB ports
    * Mic in, Line in, Line out
    * One (1) RJ-45 ethernet jack
    * Hardware Monitor Function:
    * CPU/System Fan Speed
    * System Voltage
    * CPU/System Temperature
    * Overall Dimensions:
    * 7.64 inches x 9.61 inches (W x L)
    * Supported Processors:
    * AMD Athlon XP 3000+ (166 MHz)
    * AMD Athlon XP 2600+ (133 MHz)
    * AMD Sempron 2800+ (166 MHz)
    * AMD Athlon 1.4 GHz (133 MHz)
    * AMD Duron 1.8 GHz (133 MHz)
    * AMD Duron 1.3 GHz (100 MHz)
    * Note: This version motherboard also supports AMD Geode NX 1250 / 1500 / 1750
    * Regulatory Approvals:
    * CE
    * FCC
Package Includes:
    * Biostar M7VIG 400 Socket A mATX Motherboard
    * AMD Athlon Mobile 2200+ Socket A CPU w/Heatsink and Fan
    * Drivers and Utilities CD
    * Application Pack CD
    * User's Manual
    * One (1) 40-pin, 80-wire IDE cable
    * One (1) floppy disk cable
    * I/O shield
« Last Edit: August 29, 2006, 09:27:06 pm by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
XBOX THRUSTMASTER VICTORY $50 EACH
« Reply #1 on: August 28, 2006, 02:39:46 am »
gone
« Last Edit: September 01, 2006, 01:07:30 am by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
THRUSTMASTER PC STEERING WHEEL
« Reply #2 on: August 28, 2006, 02:54:51 am »
Next up is a Thrustmaster PC steering wheel.  A simple analog steering wheel with pedals.  Analog shifting paddles act as additional axes, or can be used as any two buttons in Mame.  Four additional buttons on front of wheel.  Clamps firmly to desk with included quick-release clamp.
This wheel has no drivers or instructions.  Your PC should recognize it as an analog controller.  All axes and buttons work in Mame.
SOLD OUT
« Last Edit: August 29, 2006, 09:21:22 pm by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
ZBOARD GAMING KEYBOARDS
« Reply #3 on: August 28, 2006, 03:05:10 am »
Next up, I've got two ZBoard Gaming Keyboards.  Comes with interchangable keyboard face, and software to map the entire keyboard to your custom keyset.  Includes one gaming insert, and one standard keyboard insert, Software CD and instruction manual.  Additional keyboard inserts can be purchased separately at your favorite computer store.
SOLD OUT
« Last Edit: August 29, 2006, 09:22:05 pm by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
ILLUMINATED KEYBOARD
« Reply #4 on: August 28, 2006, 03:20:48 am »
Next up, I have a blue BACKLIT MULTIMEDIA KEYBOARD.  Includes software to map special keys for custom functions (email, programs, web browser, etc.)  Also includes playback and volume control keys, for Winamp, Media Player, etc.
Entire keyboard lights up in a cool blue color.  Manual switch turns backlight on or off.
SOLD OUT
« Last Edit: August 29, 2006, 09:22:21 pm by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
2.1 SPEAKERS W/LED
« Reply #5 on: August 28, 2006, 03:29:04 am »
gone
« Last Edit: September 01, 2006, 01:09:24 am by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
KEYBOARD DRAWERS
« Reply #6 on: August 28, 2006, 03:51:00 am »
gone
« Last Edit: September 01, 2006, 01:09:44 am by 1UP »
My other job...
NightGod
Re: Steering Wheels, Motherboards Keyboards and more
« Reply #7 on: August 28, 2006, 05:53:55 am »
PM sent on both Z-boards, Thrustmaster PC wheel and the backlit board.
« Last Edit: August 28, 2006, 06:05:29 am by NightGod »
dweebs0r
  • Last login:December 16, 2023, 04:49:40 pm
  • Ascendo tuum!
    • Jodys Garage Arcade
« Reply #8 on: August 28, 2006, 08:11:31 am »
PM sent.
-D
1UP
  • Token Junkie
    • 1UPArcade
Re: Steering Wheels and more --selling out quick!
« Reply #9 on: August 29, 2006, 09:29:02 pm »
Not much left folks!  Get em while you can.
My other job...
