Main > Project Announcements
-Projected Nexus- It's been a while
releasedtruth:
Arrrgh, double postings...
The first set is the foil curve I put behind the marquee. I have a 24" fluorescent tube facing backwards to light the marquee up cleanly. I have a second marquee I'll put in and take a pic of in a bit
The second set is the framing I made to cover the speakers. There's a 15" led strip in each socket and it's super bright so the cover material (stretched black polyester) lets enough through for a cool effect, but protects the speakers. Used some pine stripping, some wood glue, and a tasty staple gun. Came out real clean.
releasedtruth:
Been working on the front piece for the cab. My IPAC is sorta crappy so I have to get that fixed first. It's 1/4" plexi with a translucent tape, sorta like acetate that will be layed out on the back side, then 2 leds light each plexi piece, green and blue. That'll be the final piece, once the other nagging problems subside.
GT
releasedtruth:
Control panel sides. Three angles so it wraps around the sides like a hexagon. Adhesive backed vinyl, matte laminate I'm thinking. Can't wait to slap it on!
Ships originals from the Projected Nexus story I'm writing. Modeled in Maya, then traced roughly in Illustrator, imported to pshop. You guys dig?
GT
releasedtruth:
Ladies and gents, the unveiling is on Saturday! I have some pics here of the brushed aluminum sides to the control panel I just installed. It's .040 aluminum I cut and shaped to the hexagonal side to the control panel. I'll post pics of the Greylite 31 bezel in just a second!
GT
releasedtruth:
Here's the Greylite 31 bezel with retainer clips
GT
