Main > Project Announcements
-Projected Nexus- It's been a while
MYX:
Got an idea... Are you using Photoshop?
If you do, If it is a recient version you can put your layers into folders and put a mask on the folder. (So you are not distroying anything) Put the city into a folder.
Above the folder Make 2 new layers. On one do a linear fade from black to white (Black at the top of the screen and white at the bottom) and set it to Multiply. On the next one (below the fade layer) Generate Clouds then set this to multiply too. Merge the 2 layers together (click the topmost of the two, then Ctrl-E). then this layer can be used as a mask for the city. Select all (Ctrl-a) then Copy. Add a mask to the city folder and alt click the mask. Ctrl-A to select all inside the mask. Then paste the B&W stuff you just made. This should distress the city a little. You can scratch up the mask a little more. Just play with it.
If you know all this, then never mind.
releasedtruth:
Wow, that's almost exactly what I did on the final version. I'll have it back from print tomorrow which will be noooice. Looking forward to it. Have my marquee almost done. Posting soon
releasedtruth:
An update for you, I just sent the marquees off to print. I'll have 2 versions for my various moods. I also recessed the joysticks and drilled all the holes this weekend. Images to follow.
releasedtruth:
Some updates for everyone. I'm still waiting on real slow shipping on my IPAC and chrome rings, but I've wired up half the cp, the leds aren't shown, but the t-molding is on and things are nearing completion. Should have some nice marquee pics when it comes in.
releasedtruth:
Sorry I haven't been uploading the pics as I take them. I'll flood a bunch in and we can get back on topic. I have some challenging ideas ahead of me.
