Author Topic: blue P360, do they make one??  (Read 2149 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: August 25, 2006, 07:13:50 pm »
Does anyone make blue ball top or bat handles for the P360??
I b**ch. People listen!!
Grasshopper
  • Last login:November 08, 2023, 07:20:31 am
Re: blue P360, do they make one??
« Reply #1 on: August 25, 2006, 07:18:50 pm »
You can fit Wico ball top handles to the P360s. Ponyboy sells them for $2 each.
squirrellydw
« Reply #2 on: August 25, 2006, 07:27:24 pm »
thanks, I sent him a PM
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #3 on: August 25, 2006, 10:31:42 pm »
Also available are Aluminum handles from SlikStik.  Very cool.  Literally and figuratively.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
squirrellydw
« Reply #4 on: August 26, 2006, 12:40:41 am »
Thanks, I knew of them and I think they look great but  I was really looking for plastic to match my other joysticks
rockmes
  • Last login:June 05, 2016, 09:41:38 am
  • Don't you love it?
« Reply #5 on: August 27, 2006, 02:38:03 am »
yeah l bought 3 blue wico 4" handles for my p360's about 6 mths ago. Let me tell you - the best allround joystick after doing this mod. By the way Ponyboy is brilliant to deal with.
destructor
« Reply #6 on: August 27, 2006, 09:02:25 am »
I'm against it. These are too long and too heavy and ugly and ball diameter is too big.
squirrellydw
« Reply #7 on: August 27, 2006, 11:50:11 am »
He just wrote back to me and says it will only work on a metal control panel.  :(
hypernova
« Reply #8 on: August 27, 2006, 12:01:45 pm »
Ugly?  I think not!  I got the bat versions, and I like 'em.  Length is appropriate as well.
You might (should) be able to mount the 360 base on the TOP of the CP, instead of the traditional under, if that's the case in order to use those handles.
« Last Edit: August 27, 2006, 12:03:25 pm by hypernova »
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #9 on: August 27, 2006, 04:24:33 pm »
You want the 4" handles for traditional under-panel mounting with wood, unless you don't mind a shorter stick.  I guess Ponyboy doesn't have 4" left in blue?
rockmes
« Reply #10 on: August 27, 2006, 05:19:54 pm »
just what l was about to say
destructor
« Reply #11 on: August 30, 2006, 05:07:30 am »
I have red ball handle from SlikStik and for me it is ugly and color isn't red, it's purple.
squirrellydw
« Reply #12 on: August 30, 2006, 09:32:58 am »
I just ordered some 4 inch WICO blue ball tops from Ponyboy, so we will see if they do fit.
squirrellydw
« Reply #13 on: August 30, 2006, 09:28:45 pm »
Just wondering if the WICO ball tops screw off?  If so will the ball tops TornadoTerry sells work with them?
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #14 on: August 30, 2006, 10:14:20 pm »
Nope.
Quote from: saint
saint is all powerful.
Apparently he is.
squirrellydw
« Reply #15 on: September 08, 2006, 04:38:05 pm »
How did you install them?  I used everything that you normally would use except for the metal ring, is that what you did?
Kremmit
  • - AHOTW -
« Reply #16 on: September 08, 2006, 11:50:22 pm »
I believe you'll want (from the top down):
Balltop handle
Dust Washer
Pivot Cone
P360 base
P360 actuator
e-clip
and you can leave out:
Wico actuator
Wico spring (the little one that goes on the shaft above the actuator)
I think it might be possible to get a little extra handle height by using the little metal sleeve(s) and cutting the actuator shorter to compensate, although I've not tried this yet.
squirrellydw
« Reply #17 on: September 09, 2006, 05:48:22 pm »
thanks, thats what I used.
