Main > Monitor/Video Forum
Hantarex Polo 33" - how do i get it to properly display from my PC/DC/XBOX?
Pages: << < (2/5) > >>
eastbayarb:
Ok, after adjusting some settings on the monitor board, I finally got it to somewhat properly display (I am using a dreamcast with VGA adaptor for quicker testing), but when I start up, the screen is dark, then when it finally boots, the screen is split (I have attatched a photo to give you a better idea).
Any way to correct this problem?
Thanx
SORRY FOR THE DOUBLE POST, MY BROWSER SCREWED UP!
grantspain:
need that info on the label first,the fact you have 2 pictures makes is look like the monitor is on the wrong frequency
eastbayarb:
I will post info on the label tonight...how do I change the frequency?
--- Quote from: grantspain on August 24, 2006, 05:08:50 am ---need that info on the label first,the fact you have 2 pictures makes is look like the monitor is on the wrong frequency
grantspain:
well if its a polo 2 svga it should auto sync(maybe a little adjustment)-but what worries me is yours is showing 2 pictures which means its operating at 25khz,now i have heard early polo2 require some jumpers moved so i hope its that,but first i could do with some pics of the chassis from all angles-another thing to do is hook up your pc just to check its not some sort of issue of compatibility with the xbox converter-i know the guys at hantarex well so i can also contact them if we get stuck-humour me try adjusting the horizontal size pot(you can pull one of the adjusters out of one of the other pots)
eastbayarb:
grantspain,
I took a couple of pictures after removing the back part of the monitor. One is a back view of the insides, and the other is a side view of the insides. I don't see a sticker anywhere on the monitor that says the model number.  I tried my Dreamcast, XBOX, and PC, but they all have the split screen problem (picture otherwise looks great).
I have an even bigger problem now. I had the monitor with the Dreamcast on and I started adjusting the knobs and all of a sudden, the monitor just turned off! I immediately turned off the cab, waited several minutes, turned the cab back on, but the monitor has no picture (I don't even hear it on)! HELP!
Go to full version
