Main > Monitor/Video Forum
Hantarex Polo 33" - how do i get it to properly display from my PC/DC/XBOX?
Pages: << < (5/5)
eastbayarb:
thanks for the guide, but do you have any pictures to support this? By meter, I am assuming you mean a multimeter?
I hope I won't have to install a cap kit
grantspain:
i take some pics tomorrow ar work,meter yes multimeter-its not gonna need a cap kit,the most you will need is the h.o.t and possibly a resistor
StephenH:
1) If it is 15Khz, and you want to connect it to a PC, use an ArcadeVGA card
2) To connect a Dreamcast, you make a cable to its connector, and ground of the pins on it:  http://www.gamesx.com/wiki/doku.php?id=av:dreamcastav
3) To connect an X-Box, the wiring is similar to Dreamcast:
http://www.gamesx.com/avpinouts/xbox.htm
eastbayarb:
BUMP
monitor for sale $150 pickup only in Bay Area, California if anyone wants it. It is currently mounted in my showcase cab, but I don't have the means to repair it at present time.
email eastbayarb@gmail.com DO NOT PM!
Sergioscabone:
Hello guys.
I’ll be greatfull If anybody can help me with this.
  I have a Hantarex polo/2 34” SVGA monitor, witch came with a vga connector.
  I use this monitor connected to a Sega Naomi, set at 31khz, and works ok.
  I plug this monitor to a Toshiba netbook with windows xp, and set the resolution to 800x600, and guess what? IT WORKS FINE!!
  So I buy a new computer that can run demul to use it. Set the resolution to 800x600 but nothing...
  I try:
  800x600 60hz
  800x600 56hz
  640x480 60hz
  640x480 67hz
  640x480 72hz
  640x480 75hz
But non of it works...
Pictures:
https://imgur.com/gallery/AvfKvXc
  Anybody can help me with this?
(By the way, my new computer it is an Athlon 3000 g - Asrock a320m-Hdv)
Pages: << < (5/5)
Go to full version
