Main > Monitor/Video Forum
Hantarex Polo 33" - how do i get it to properly display from my PC/DC/XBOX?
Pages: << < (4/5) > >>
eastbayarb:
Thank you!
my direct email adress is eastbayarb@gmail.com
grantspain:
i am going to post my help on this forum as it could help people in the future,i'm gonna do it tomorrow as its my day off and i can concentrate a bit better-just remember you will need;soldering iron,desoldering tool(solder sucker),solder,a meter is very handy and of course a bu508a or bu508af transistor to replace the faulty one,and heat conductive grease to do this professionally
eastbayarb:
where would i get those bu508a or bu508af transistors you are talking about?
grantspain:
i am not familiar with stores in the u.s but i guess somewhere like radioshack(if they still exist)-but wait until tomorrow as if you have a meter you can read whether the h.o.t is short or not,i will give you all the info
grantspain:
the first thing we need to do is access the monitor safely;(using pic 1 as a guide)
switch off machine and unplug from mains
disconnect the rgb signal,power in and the remote adjustment board plug
unscrew the 2 cross head screws that hold the chassis to the frame(its the 2 you can see in the first picture)
there are 2 more plugs to remove now,the first is the degauss(its the 2 pin plug on the far left) and the yoke plug(green plug of 4 wires on the right hand front of the chassis)-use a flashlight and if not sure then post pics marking the ones you believe are correct.
once these plugs are removed you need to remove the neck card,(first remove the metal bar across the neck card on the frame)to do this you have gently hole each side of the neck card and pull back with equal force slowly-once the card is removed you will see a black wire with a spade type connector that goes to the crt earth,remove this
this now enables you to move the chassis,push the chassis gently up and towards yourself and it will move off the locating lugs at the front then you move your chassis to the right and out of the frame or being careful angle it through the centre of the frame-ALWAYS REMEMBER TO KEEP AWAY FROM THE NECK OF THE TUBE AS IT IS VERY DELICATE AND IF YOU CRACK IT YOU WILL NEED A NEW TUBE.
the only wire now connecting your chassis to the tube will be the h.t lead(thick red wire that goes from the flyback to the anode cap on the tube),now you can find a chair or table to place the chassis on whilst you work on it(remember you can only move a little way because of the h.t lead still being connected,sometimes there is a cable tie on the ht lead that stops you moving the chassis far-you can snip that off.
now you should have the chassis in a position where everything is accessible-you need to look for transistor number T114,this is the horizontal output transistor-you can locate this by looking at the top(component side) of the chassis on the right side you will see the flyback shield(a silver metal surround that acts a heat sink),on the right hand side of that you will see a large transistor that is spring clip held to that shield-this is the h.o.t and you will see the transistor number T114 written on the board next to it.
to meter this transistor set your meter to ohms and put your black probe in the common socket of the meter and your red probe in the Va/c,Vd/c,ohms socket-place one probe on the metal shield and the other on the center leg of the transistor if its reads short(let me know the reading) then the h.o.t is short and needs replacing-LETS GET TO THIS POINT FIRST BEFORE WE GO ON,and remember take your time and be careful if something does not want to move there is a reason,also post pics at any time if you are not sure-good luck
Go to full version
