Main > Monitor/Video Forum
Hantarex Polo 33" - how do i get it to properly display from my PC/DC/XBOX?
Pages: << < (3/5) > >>
grantspain:
thats a polo 1 15khz only monitor it won
eastbayarb:
--- Quote from: grantspain on August 25, 2006, 09:20:11 am ---thats a polo 1 15khz only monitor it won
grantspain:
not as simple as a fuse im afraid,the clicking you hear is the power supply of the monitor in trip mode,this is because the horizontal output transistor is blown(caused by having the wrong frequency signal fed to it)-you need to replace the transistor(its probably a BU508AF),this will bring your monitor back to life then you need to look at options e.g run from pc only using arcade vga card or a vga to cga converter-i can talk you through the repair and you don't have to remove the anode cap,its a very simple repair if you follow my instructions to the letter and are careful whilst removing the monitor chassis to a point where the transistor is accessible.
the polo range monitors come in 4 types-polo,polo2,polo3 and polostar only the polostar and polo2 svga run from standard vga inputs-if i had seen your label on your first post i would have told you not to feed it a vga signal,i know that don't make you feel better but you should be able to sort this out-also have a moan at the person you bought it from,there is no way that  monitor should ever have been described as a vga arcade monitor
eastbayarb:
--- Quote from: grantspain on August 26, 2006, 01:03:56 pm ---not as simple as a fuse im afraid,the clicking you hear is the power supply of the monitor in trip mode,this is because the horizontal output transistor is blown(caused by having the wrong frequency signal fed to it)-you need to replace the transistor(its probably a BU508AF),this will bring your monitor back to life then you need to look at options e.g run from pc only using arcade vga card or a vga to cga converter-i can talk you through the repair and you don't have to remove the anode cap,its a very simple repair if you follow my instructions to the letter and are careful whilst removing the monitor chassis to a point where the transistor is accessible.
Ok, I am ready to repair this thing. I have already been able to unscrew the part of the monitor chassis to where I can work on it. Just tell me what to do...
grantspain:
o.k its midnight here in spain and time for bed so what i'm gonna do is get my polo schematics tomorrow at work and i will step by step take you through all the stages of repair so until tomorrow hasta luego
Go to full version
