Main > Main Forum
Slot Depth?
Jakobud:
Haha. No it won't matter if it's slightly deeper.
medley:
I'm ptretty sure that:
For 3/4" wide T-Molding the slot should be 3/32" wide and 5/16" deep.
For 5/8" wide T-Molding the slot should be 7/64" wide x 9/32" deep.
DeathMonk:
The bit that I used went in 3/4" :).. It still worked perfect.
slug54:
The slot cutter I used had a berring that rides on the edge of the wood where the slot is being cut.There was no depth of cut adjustment it just does it. but if your using some other method to cut the slot ,just go a little deeper then the piece that goes in the slot.
Slug54
radiator:
better to go a bit deeper than not deep enough (and then have to get the tools out and do it again!)
:P
