Author Topic: Difference between Sanwa JLF-TP-8YT and JLW-TM-9??  (Read 6940 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: August 17, 2006, 02:36:48 am »
Hi all!
I have the JLW-TM-9's in a cabinet, and are pretty happy with them.
Then I see these(at the top, the ones I have now at the bottom)
http://www.gremlinsolutions.co.uk/sanwaparts.htm
It seems that the 8YT's have some sort of PCB under them?? and a cable?
Can anyone tell me the main difference?
Thanks again!
Nicholas
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Re: Difference between Sanwa JLF-TP-8YT and JLW-TM-9??
« Reply #1 on: August 17, 2006, 04:02:36 am »
JLF microswitches they are better (Omron)
mode 4 way it acts bad
parameters are identical (differences can be the mistakes of measurement)
you can buy JLF from octangonal restrictor (this is excellent 4 fighters, platform, shooter-walking)
if you use square restrictor. then change JLW/JLF has not sense (you lose mode 4 way only).
AE35
« Reply #2 on: August 17, 2006, 04:11:36 am »
It will be used in 4-way mode....doesn't it have a restrictor plate I can turn,
like the JLW-TM-9's, making it 4-way?
Can you tell me if the throw is shorter on the JLF-TP-8YT's?
Is the stick the same length?
kowal
  • Suzo 4ever
« Reply #3 on: August 17, 2006, 04:51:34 am »
If you have version JLW EU/USA (69mm stick) all is similar. Throw version japanese JLW  (62mm) is shorter similarly how Seimitsu LS32
mode changes unbuttoning restrictor. this is uncomfortable very.
AE35
« Reply #4 on: August 17, 2006, 05:05:25 am »
Sorry, can you tell me why it's uncomfortable?
So, if I wanted a better 4-way than the Sanwa JLW-TM-9's, what would I use?
I have the IDEA(!) that I would like a little bit shorter throw! Lady Bug is a big
player on the machine, so is Burger Time etc.
Thanks so far, kowal!!
kowal
  • Suzo 4ever
« Reply #5 on: August 17, 2006, 05:15:17 am »
see on photo this can not be altered quickly.
if you want to have the short throw (on 4-way mode) bay the mag-stick or
seimitsu 32
seimitsu LS40
restrictors on Seimitsu they are poor (they can destroy)
MAg - stick is more solid from seimitsu
on JLF diagonals in mode 4way are hit still!
« Last Edit: August 17, 2006, 05:22:47 am by kowal »
AE35
« Reply #6 on: August 17, 2006, 05:19:43 am »
I don't need it to be changed quickly. I like fixed things ;) It will stay in 4-way.
Ohh...the Mag-stick I don't like!!
destructor
« Reply #7 on: August 17, 2006, 05:57:15 am »
For JLW you can buy circle restrictors, for JLF octagonal restrictors. Sanwa spring (JLW) is a bit harder than Seimitsu LS-32. Diagonals on circle restrictor in JLW aren't easy to hit, I think are identical as in not moded P360 joystick.
PS. P360 still the best for shooters ;)
NIVO
  • Last login:August 08, 2022, 12:32:13 pm
« Reply #8 on: August 17, 2006, 11:54:08 am »
JLF sticks will also work as a 4-way if left in 8-way mode on the base of the stick itself. You'd need to add something like an Oscar restrictor plate to the top of your panel.
