| Main > Main Forum |
| Narrowest usable CP dimensions? |
| << < (2/2) |
| Gambit:
Slightly angle them away from each other, and you can fit them in a smaller space. If you are both turned slightly away from each other your elboes wont bump. |
| Level42:
Yup......my CP is 60 cm too. Any smaller and you can't play without being in the way of eachother... |
| phil001:
I was just about to ask this question! I want to make a desktop cabinet and hoped to be able to make it 2 player. Thinking that anything more than 500mm (about 20") wide might look odd for a desktop? Has anybody seen a 2 player 12 button desktop cabinet before?# |
| releasedtruth:
I may be able to get away with adding another 1". I'll check the plans and see if I can squeeze it in. It'll make the width 28" which is pushing it for getting in the doorway, even with the door off the hinges. |
| davieboynj:
remember, the wider you make it, the worse if feels for 1 player games, especially if you're not packing a 25" screen. if it's primarily for fighters, go for the additional width, but you really should be fine at 24-25", IMPO... |
| Navigation |
| Message Index |
| Previous page |
