Author Topic: Marquee wall display...  (Read 891 times)
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« on: August 14, 2006, 06:33:31 pm »
In numerous arcades I have seen what I would describe as a "light box" or sorts that displays around six arcade marquees on the wall.  Has anyone else seen these and does anyone know where to buy one or how to build one.
Thanks in advance.
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
MYX
    • MYX Digital Blog
Re: Marquee wall display...
« Reply #1 on: August 14, 2006, 07:08:43 pm »
Planning on it once the cab is done.
First decide how many marquees you want. Investigate the dimensions of each marquee (as they come in all sorts of sizes). Start collecting. Collect first. It may take a while unless you have a wad of cash. Then the box can be whatever size you like. You may want to make like 3 columns. You will need to route a 3/16 to 1/4 in. slot around the edge then slide the marquee in. Seperate with like a 3/4 in. piece of wood also slotted. This should slide right over the edge of the marquee and block any light from comming out. The trick is figuring out what kind of light to use and how many. Cold cathode would be great and low power, but somewhat costly for something this sized.  Sorry if this is vague. I have roughly sketched plans that I have been toying around with.
I have a few marquees collected, but have a lot more to go.
M    Y    X
Lutus
« Reply #2 on: August 14, 2006, 07:20:49 pm »
Thanks MYX for the response.  Most arcades owners are not into making their own things so they must buy them from somewhere...
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: August 14, 2006, 07:57:25 pm »
They probably call a commercial sign shop.
NO MORE!!
MYX
    • MYX Digital Blog
« Reply #4 on: August 14, 2006, 10:58:54 pm »
Yeah, but where's the fun in that?
M    Y    X
jhanson
« Reply #5 on: August 15, 2006, 06:54:33 am »
Here's a nice one that someone made a while back:
http://forum.arcadecontrols.com/index.php?topic=46211.0
