Main > Main Forum
Joysticks & Buttons
Pages: << < (2/3) > >>
rampy:
--- Quote from: dolphinwaxer on March 15, 2003, 12:50:35 am ---Oh ya, I forgot to ask, can anyone reccommend an inexpensive spinner or maybe some plans for a 'homebuilt" one?
thanks!
Why yes, I can!
If you have the bread, of course go for one of the oscar spinners ( oscarcontrols.com ) but if you have your heart set on DIY here is a relavent thread:
  relevant thread
good luck
Rampy
IG-88:
You're too kind, thank you very much!
So do you have any good ideas for trackballs?  ;D
rampy:
--- Quote from: dolphinwaxer on March 15, 2003, 08:35:46 pm ---You're too kind, thank you very much!
assuming you want a 3" "real arcade"  trackball  on the cheap... you could get a refurbished imperial betson direct form imperial betson usually for 29.99 and hack a mouse to it.  (or keep a close watch on ebay for one of the ones that already have ps/2 interface)   Regardless of which arcade trackball (or where ) you hypothetically get, I highly recommend getting the mounting plate to make things easier (although a few people have gotten creative and mounted their trackball s without mounting plates - the plate makes it soo much easier)
Another option (although the mounting is a little trickier) is to find a crayola trackball sometimes called a KYE Kidsball in a closeout store or in the clearance section somewhere... (they have 3" balls and are  a reasonable facisimile of an arcade trackball)
You could work a cheapo PC trackball into your panel - depending on how much you actually like/played trackball type games in the arcade will probably dictate how happy you'll be with that "half measure" ...  for me (and others) it's mostly a matter of feel - Golden Tee PC version is just not the same with a regular trackball - need the arcade bulk and "whiz"...
*Shrug*
good luck
rampy
Mamezilla:
--- Quote from: rampy on March 15, 2003, 10:35:22 pm ---assuming you want a 3" "real arcade"  trackball  on the cheap... you could get a refurbished imperial betson direct form imperial betson usually for 29.99 and hack a mouse to it.
I've checked the Imperial Betson website at www.betson.com and cannot find there any information on those refurbished trackball.  Are they available on their website ?  Where could those be found ?
UPDATE:  Never mind, I found them finally.  They are still at $29.99.  One small missing information tought:  do those trackball need any mounting plate ?
rampy:
The question on the floor is:
"do those trackball need any mounting plate ?"
They don't "need" one if you are sufficiently crafty.... however for the rest of us it makes the most sense to use a mounting  plate...  as that's how it's done in the arcades (unless you have a metal control panel that is)
The imperial betson (mounting hole wise) is the same as the happs trackball ...   In fact I use a happs mounting plate with my imperial betson refurb...
Rampy
Go to full version
