Author Topic: Can I cut and splice a USB cable?  (Read 6394 times)
MYX
    • MYX Digital Blog
« on: August 10, 2006, 09:37:12 am »
I have a couple 6 ft. USB cable for my GGG 49 ways that are about 4 ft. too long. I do not see a reason why cutting 4 ft out of the middle would be a bad thing as long as it was soldered and heatshrinked properly back together. But then again, I know that there are all sorts of tollerances for stuff, so I did not know if this was out of bounds or not.
Any ideas?
M    Y    X
NightGod
Re: Can I cut and splice a USB cable?
« Reply #1 on: August 10, 2006, 01:29:53 pm »
I can't see there being a problem as long as you are going shorter-it's extra length that USB doesn't like.
MYX
    • MYX Digital Blog
« Reply #2 on: August 10, 2006, 01:34:49 pm »
True.
I am not sure about sheilding n such.
M    Y    X
Mr Ironpants
  • Last login:October 14, 2009, 02:14:44 am
  • Take off to the Great White North
« Reply #3 on: August 10, 2006, 01:39:52 pm »
I have done both shorten and lengthen USB cables with no problems.  Although to be fair the added length was only a couple of feet and the application was pretty low demand.  Here is a decent step by step tutorial that I used when I need to hack up a camera cable about a year ago.
http://www.fixup.net/tips/usb/index.htm
Since then I have done the typical XBox to PC usb hack and some other stuff and have been very happy.  Besides unless I am mistaken about the GGG 49's usb interface, the worst that happens is you get a couple more cables if you mess it up.
Happy splicing  :cheers:
Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life. - Terry Pratchett
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #4 on: August 10, 2006, 02:19:51 pm »
Just be forewarned that USB cables tend to be quite small. I wouldn't attempt it unless the cable is exceptionally fat or you are fairly experienced.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
« Reply #5 on: August 10, 2006, 02:43:14 pm »
I spliced a VGA cable to another VGA cable because of a bad connector and had no problems.  Those wires inside are thin, and some have braided shieding and teflon insulator over them.  It was tedious, and ugly, but it worked, I can see no video degradation on the monitor after I got it working again.
USB cables I would think would be more forgiving.  Good luck.
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
Outrun
  • Last login:September 23, 2006, 08:41:54 am
« Reply #6 on: August 10, 2006, 03:27:29 pm »
Hi,
We do this from time to time at work, when users want their USB printer cables a little longer than the shipped 1m or 2m (for shortening we just cable tie them!!).
Haven't had any problems reported back yet.
My wife doesn't understand !!
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
« Reply #7 on: August 10, 2006, 11:02:30 pm »
Why not just buy a shorter USB cable?
They're not really that expensive as long as you don't do anything stupid like trying to buy them at "Best Buy".
http://froogle.google.com/froogle?hl=en&lr=&safe=off&c2coff=1&q=2ft%20usb%20cable
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #8 on: August 10, 2006, 11:07:04 pm »
Nice to see that *somebody* isn't overengineering the solution ...  :cheers:
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
NightGod
« Reply #9 on: August 10, 2006, 11:08:42 pm »
To be clear, the maximum spec length on a USB 2.0 cable is 15 feet. You can make it longer by using powered repeaters.
Sizzler
  • Last login:January 25, 2008, 12:28:46 am
« Reply #10 on: August 11, 2006, 05:31:58 am »
Amen.  Check www.pcmicrostore.com   they always seem to have USB cables for a few bucks and free shipping.
MYX
    • MYX Digital Blog
« Reply #11 on: August 11, 2006, 10:10:37 am »
I had checked frys but they wanted 6.99 for a 1 ft. They also had a 3 ft for the same cost. I need 2ft. I checked Target, wallymart, radioschwag and they only had like 6 and 8 ft. I am looking at that site now. Thank you.
M    Y    X
Sizzler
« Reply #12 on: August 11, 2006, 11:47:22 am »
I scanned through it and I'm not sure they've got exactly what you need with free shipping.  ANother option would be to check places like Big Lots and the dollar store.   You might have a hard time finding 2ft cables for uber cheap.
Good luck
krick
Hantarex Polo 15KHz
MYX
    • MYX Digital Blog
« Reply #14 on: August 11, 2006, 03:22:58 pm »
Good luck
Yeah, at this point I have put out so much money for this thing, every dollar hurts now. So seing that I would be needing 3 cables ($18) I would rather take a couple hours and just solder. Gots the skilz ya know.
M    Y    X
