Author Topic: software for identifing game categories  (Read 1118 times)
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« on: August 07, 2006, 04:48:35 pm »
is there a software out there that will break up my games into categories such as all pinball, fighting etc...
I am running gameex and it does a pretty good job but does not do all such as pinball.  thanks
Its easy to like someone,
If you dont know them very well.
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: software for identifing game categories
« Reply #1 on: August 08, 2006, 05:48:48 am »
Give a try to AtomicFE.
I have a plug'n play module called mame_youki1    , it allows to choose your mame games by categorys. (and you have pinball).
You just need to 5 minutes to test.
Go to my website :
-Download :  AtomicFE 0.17-2  (fullversion)
-Install it (touch nothing, configure nothing)
-Donwload the : mame_youki1  plug'n play module  (on the plug'n play page)
-Install the module
-Just copy your roms in the  <atomicfe>\plugnplay\mame_nuss\roms  folder.
-run Atomic.exe
That's all.
Press "Player1 Start" button or Enter Key to enter in a category or run a Game
Press "Player2 Start' button or Backspace  Key to exit a category
Mame version in the module is a 0.102 one. (but can be changed)
kiddk1
  • HAP KI DO
« Reply #2 on: August 09, 2006, 04:44:19 pm »
I have way too many roms to move to the <atomicfe>\plugnplay\mame_nuss\roms  folder, is there a way to tell atomic where to access them?
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #3 on: August 09, 2006, 06:23:12 pm »
Too many roms to move? What are you using? Commodore 64? Atari 800?
Quote from: saint
saint is all powerful.
Apparently he is.
kiddk1
  • HAP KI DO
« Reply #4 on: August 09, 2006, 09:58:58 pm »
Atari 2600
what I mean is that the roms would have to be moved then gameex would have to be reprogrammed,(okay call it lazy)  I did do a test on my second pc, I installed and put in about 40 pinball games but only 15 showed up under atomic.
« Last Edit: August 09, 2006, 10:04:53 pm by kiddk1 »
youki
    • Atomic Front End
« Reply #5 on: August 11, 2006, 10:21:22 am »
There are not showed because they are not in the gamelist.   (what romset have you?)
You can add easly your missing pinball game in the gamelist.
Go in the folder :
plugnplay\mame_nuss\MultiConf_mame5
open with the notepad  :  Pinball.cfg.GAMELIST
And add your  missing roms. It will appear in Atomic then.
youki
    • Atomic Front End
« Reply #6 on: August 11, 2006, 10:25:30 am »
I miss that one :
To modify the plugnplay module you use , you will have to change the ROM folder for each categories.
Open each .CFG files that are in the : plugnplay\mame_nuss\MultiConf_mame5  folder  with the notepad and change the line :
ROMDIR= .........    by your rom folder.
You can do that by opening the .CFG file using AtomicManager too.  But it will be faster with the notepad in that case i think.
