Main > Main Forum
RomSet folders?
squirrellydw:
I am talking about NES
Matthew Anderson:
Uhh, (J) apanese (E)uropean, (U) America for starters....
Or so I hear..
You could give one a clue as to what characters are on the end....?
squirrellydw:
--- Quote from: Matthew Anderson on April 11, 2007, 10:53:09 pm ---Uhh, (J) apanese (E)uropean, (U) America for starters....
Or so I hear..
yeah, sorry I was at work when I asked.
OK, that explains a lot but what about these?
(U) [01], (HES), (VS), (U) [b1]
I am guessing (U) [01] is USA with a newer dump? It least the I have an idea of what ones to use now. Thanks
um3k:
Included in every download of GoodTools is a file called GoodCodes.txt which explains the codes. Reposted here for your enjoyment....
--- Code: ---...............: STANDARD CODES ::...............
: [a] Alternate [p] Pirate :\
: [b] Bad Dump [t] Trained :\
: [f] Fixed [T-] OldTranslation :\
: [T+] NewerTranslation :\
: [h] Hack (-) Unknown Year :\
: [o] Overdump [!] Verified Good Dump :\
: (M#) Multilanguage (# of Languages) :\
: (###) Checksum (??k) ROM Size :\
: ZZZ_ Unclassified (Unl) Unlicensed :\
................: SPECIAL CODES ::...............
: .-----Gameboy-----. .----Super Nintendo----. :\
: [ [C] Color ] [ (BS) BS ROMs ] :\
: [ [S] Super ] [ (ST) Sufami Turbo ] :\
: [ [BF] Bung Fix ] [ (NP) Nintendo Power ] :\
: .--------Atari---------. :\
: .-----Genesis-----. [ (PAL) Euro Version ] :\
: [ (1) Japan ] `----------------------' :\
: [ (4) USA ] .---------GBA----------. :\
: [ (5) NTSC Only ] [ [hI??] Intro hacks ] :\
: [ (8) PAL Only ] `----------------------' :\
: [ (B) non USA ] .--------Coleco--------. :\
: [ [c] Checksum ] [ (Adam) ADAM Version ] :\
: [ [x] Bad Checksum] `----------------------' :\
: [ [R-] Countries ] :\
: .--------NES/FC--------. :\
: .--NeoGeo Pocket--. [ (PC10) PlayChoice 10 ] :\
: [ [M] Mono Only ] [ (VS) Versus ] :\
: `-----------------' [ [hFFE] FFE Copier fmt] :\
................: COUNTRY CODES ::...............
: (1) Japan & Korea (4) USA & BrazilNTSC :\
: (A) Australia (J) Japan :\
: (B) non USA (Genesis) (K) Korea :\
: (C) China (NL) Netherlands :\
: (E) Europe (PD) Public Domain :\
: (F) France (S) Spain :\
: (F) World (Genesis) :\
: (FC) French Canadian (SW) Sweden :\
: (FN) Finland (U) USA :\
: (G) Germany (UK) England :\
: (GR) Greece (Unk) Unknown Country :\
: (HK) Hong Kong (I) Italy :\
: (H) Holland (Unl) Unlicensed :\
.............: STANDARD CODE NOTES ::............
: [a] This is simply an alternate version of a :\
: ROM. Many games have been re-released to :\
: fix bugs or even to eliminate Game Genie :\
: codes (Yes, Nintendo hates that device). :\
: [b] A bad dump often occurs with an older :\
: game or a faulty dumper (bad connection). :\
: Another common source of [b] ROMs is a :\
: corrupted upload to a release FTP. :\
: [f] A fixed game has been altered in some way :\
: so that it will run better on a copier :\
: or emulator. :\
: [h] Something in this ROM is not quite as it :\
: should be. Often a hacked ROM simply has :\
: a changed header or has been enabled to :\
: run in different regions. Other times it :\
: could be a release group intro, or just :\
: some kind of cheating or funny hack. :\
: [o] An overdumped ROM image has more data :\
: than is actually in the cart. The extra :\
: information means nothing and is removed :\
: from the true image. :\
: [t] A trainer is special code which executes :\
: before the game is begun. It allows you :\
: to access cheats from a menu. :\
: [!] Verified good dump. Thank God for these! :\
--- End code ---
squirrellydw:
thanks, that is perfact
