Main > Main Forum
Methods to secure CP to CP box
Brogner:
I'm doing something a little different. I'm using dowel rods to attach my cp. I have 2 holes on each side of the cab that go through a wood piece attached to the cp. it locks it in well with a slight wobble if you try to lift it. I can pull the dowels out to remove the cp. I had to use the wood to raise the cp 1/2" to clear the coin door and allow the wiring into the cab, so this worked out well
