Main > Main Forum
Another layout question
NightGod:
Wait, if I read that right, you are planning on using Atari cones as regular buttons? Not just as Player start buttons?
That seems really odd to me.
Animeka:
--- Quote from: NightGod on July 29, 2006, 12:59:44 pm ---Wait, if I read that right, you are planning on using Atari cones as regular buttons? Not just as Player start buttons?
That's what was used for Missile Command on the original cabinet. Lighted ones for the P1/P2 and black non lighted ones for the 3 play buttons...
Marc
Animeka:
Here's the current layout I did, installed on the cabinet (it drooped a bit when I took the picture, hard to keep a cardboard panel steady ;))
Comparing this panel to the current metal one i have, the 2 player configuration is in the same position, the trackball has plenty of space to spin.. The only thing is I'll move P1 about 1/2-1" to the right, it's too close to the wall of the cabinet.
Marc
RobotronNut:
have you tried two players side-by-side with your mock-up?
looks a little tight...
Animeka:
--- Quote from: RobotronNut on July 29, 2006, 02:13:04 pm ---have you tried two players side-by-side with your mock-up?
That's the same layout for 2 player that I have on the cabinet right now... plays shoulder to shoulder but plays fine. :)
