Main > Main Forum
Laminate similar to xarcade?
OSCAR:
I'm not sure about the X-Arcade, but if it is anything like the HotRod then it is a textured Lexan. I think the HotRod actually uses a velvet lexan, but I don't know for sure.
Something like this (self-adhesive style)? http://www.3m.com/us/mfg_industrial/adhesives/pdf/7737FL.pdf
Velvet lexan should be available at most good print shops and they can reverse print on it. I've called a few shops around me, and I didn't have much trouble finding it. I was thinking about having my cp art reverse printed on velvet lexan and then using some kind of adhesive to stick it down, just like the HotRod. I'd check with the print shop first to see if they had any recommendations on an adhesive or an alternate way to hold it down, though.
jon:
yes it is textured........how much are the print shops charging the velvet lexan?
reverse printing? do you mean they'll scan your art and print it on the lexan for you?
SNAAAKE:
--- Quote from: jon on March 12, 2003, 11:07:33 pm ---yes it is textured........how much are the print shops charging the velvet lexan?
I recall there was a guy did this..reverse print on lexan.
the arcadeshopper guy right?
http://arcadeshopper.com/
Email the guy and see if he will do(i know he does marques that way)
