Main > Main Forum
Intermittent Missed Keys with iPac **Resolved**
DigDreams:
No, the wires go directly from the I-Pac2 to the Button. Nothing in-between.
- DigDreams
DefJam:
Hey,
I too have that problem, but in my case I know it has nothing to do with the encoder... I use a toshiba laptop and it clearly misses key strokes once in awhile in visual pinball (using the shift keys).... I read somewhere once that someone else with a Toshiba laptop was having the same problem.
I have been unable to figure out what it is...
Jim
hanelyp:
--- Quote from: DigDreams on July 24, 2006, 12:54:42 am ---...If I hit keys connected to the ipac 10 times I get either 10, 9 or even 8 key presses some times.
Does it make a difference if you press and hold for a moment vs. tapping the buttons?
DigDreams:
--- Quote from: hanelyp on July 29, 2006, 12:34:09 am ---Does it make a difference if you press and hold for a moment vs. tapping the buttons?
Not at all.
DigDreams:
It was a bad IPac2 chip. I got my new chip from Andy today, popped it in, and now everything works perfectly.
It even remembered it's programming. I thought after swapping the chip I would sureley have to re-program it.
- DigDreams
