Main > Main Forum
CPO + Plexi or Only CPO????
<< < (2/2)
SurferMatti:
Ahhh... Well thanks for the replys.  Think I might go with the cpo alone.
ahofle:
I like the look of my lexan cover, but if I had to do it over again, I'd probably not do it, especially given the tough overlays that are available now.  The cutting and drilling of lexan is not something of which I have found memories.
BlinKY1337:
Nothing beats the look of some good artowrk under a nice layer of plexi glass  ;D think of it like framing a picture vrs using thumb tacks to pin it on your wall  Get a fornster bit and either score it slowly then snap it or use a router to cut
DaveMMR:
The addition of Plexi/Lexan is a bit more of a hassle and expense than I'm willing to add.  Well - it's not expensive really unless you're like me and will have to buy three times as much material since you know you'd screw up the first two.  Nontheless, still a hassle considering the home cab is usually in a controlled environment (unless you have friends who put out their cigarette on your furniture).  You can do without the covering - but that's just my opinion.  I would only do it if I really liked the look.
leapinlew:
--- Quote from: BlinKY1337 on July 21, 2006, 01:43:10 pm ---Nothing beats the look of some good artowrk under a nice layer of plexi glass  ;D think of it like framing a picture vrs using thumb tacks to pin it on your wall  Get a fornster bit and either score it slowly then snap it or use a router to cut
I disagree...
Think of it as having a Mona Lisa and hanging it on the wall, or imagine putting a piece of plexi over her.
It's personal preference.
Navigation
Message Index
Previous page
Go to full version
