Front End Support > MaLa Frontend
MALA exacute help
gamecreature:
http://www.lavasoftusa.com/software/adaware/
If that doesn't work, try Spybot Seek and Destroy.
unclet:
Yes, AdAware and Spybot are the most common used spyware removal software.
Spybot site ==> http://www.spybot.com/en/index.html
If this is the first time you ever ran spyware removal software, then you probably will have a lot of spyware on your machine (just a guess from past experience). When the "scan" is complete, just select everything it finds and request it to be deleted.
MARINE1142:
I will do that thanks again. You think maybe that is the reason for the game window to go to min. Well we will just have to kill that poka and see. Thanks again guys.
unclet:
I am not sure if the pokapoka.exe is causing your windows going to min, but I bet there is some other spyware on your machine which is causing that to happen ......
leapinlew:
Try:
Fdisk and Format...
I've just about given up trying to clean systems. To me it's like a girlfriend that cheats on you - you just can't ever have the same level of trust again. Once a machines been compromised, I never feel it's the same so I format'em.
Often times, cleaning a system takes as long or longer than formatting a system.
Navigation
[0] Message Index
[*] Previous page
Go to full version
