Author Topic: Help with Mamewah  (Read 1235 times)
MARINE1142
  • Last login:July 02, 2009, 03:00:59 pm
Help with Mamewah
« on: June 22, 2006, 01:06:07 pm »
Well I installed the mamewah program a little bit of problem but it seems to work. Now i have the mamewah setup screen also i install the emulator i want and the rom path and it comes up on the mamewah screen the FCEUltra for nes roms works but the game screen never takes up the whole screen it stays as a small window how do i change that. Also when i use the second emulator which is kega Fusion for the sega genesis setting are the same as the nes emulator it never runs it freezes the mamewah screen and locks up and i have to end the program with a ctrl alt del can you tell me what i m doing wrong there?
MARINE1142
Re: Help with Mamewah
« Reply #1 on: June 22, 2006, 05:51:43 pm »
Anybody? Any Ideas,or leads?
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
« Reply #2 on: June 22, 2006, 05:58:06 pm »
You need to configure your video setting sfor FCEUltra within FCEUltra itself.
Fusion should work. I would suggest your fusion ini settings are incorrect. You'll need to provide more information such as your Mamewah Fusion.ini and a mamewah log.
Brad
MARINE1142
« Reply #3 on: June 22, 2006, 11:20:38 pm »
i dont know were the ini files are
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #4 on: June 23, 2006, 12:53:10 am »
Your mamewah files are in your mamewah folder in the config folder if you are using 1.62. :dizzy:
Brad
    • www.emuchrist.org
« Reply #5 on: June 23, 2006, 01:27:15 am »
I've just bailed on this thread then.  :banghead:
Brad
MARINE1142
« Reply #6 on: June 23, 2006, 10:41:40 am »
I read the wiki page but was unclear were to find the ini file. I feel  :banghead: that too thanks for the effort.
unclet
« Reply #7 on: June 23, 2006, 11:52:33 am »
Try MALA instead ... no INIs required ...
MARINE1142
« Reply #8 on: June 29, 2006, 01:10:46 pm »
Looking around in this forum i found a screen shot of MALA it was cool it had the name of the game and screen shot text to it. Is that possable to have on mamewah?
and if it is does anyone have a screen shot so i can see what it looks like.
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
« Reply #9 on: June 29, 2006, 09:24:45 pm »
Looking around in this forum i found a screen shot of MALA it was cool it had the name of the game and screen shot text to it.Is that possable to have on mamewah?
Could you tell me what forum thread had the screen shot?
In any case I'm sure you could do it in MameWah, it just might be a bit more fiddly to set-up for a beginner
« Last Edit: June 30, 2006, 05:20:35 pm by loadman »
Havok
  • Trade Count: (+17)
« Reply #10 on: June 30, 2006, 01:14:18 pm »
I'm an AtomicFE user, but there is a config utility for Mamewah: it only works (fully) for version 1.61. You can download it here:
http://www.bluecamel.org/software/mc/mamewahconfig_161.1.zip
Note: it requires .Net Framework 1.1
« Last Edit: June 30, 2006, 01:20:10 pm by Havok »
loadman
    • MaLa
« Reply #11 on: July 01, 2006, 06:15:08 am »
(I don't use mamewah on my Cab because I want some 'on the fly' screen rotation options from the FE)
anyway............
I just tried this tool for interest sake
I think Steve did a good job on that config tool. He obviously put a lot of time into it.
« Last Edit: July 01, 2006, 06:19:55 am by loadman »
