Main > Main Forum
Quick Disconnects
Siris:
MinerAl,
.187 is what cherry switches have yes, That is not what you got at Wal-Mart though. They only have .250 as far as I've seen.
.250's will work but if you are a stickler for details like myself it just won't do. heh
As I said previously NAPA is the place to go without sending for them, Every town has a NAPA! :)
BTW: NAPA doesn't have them labeled as .187 they are labeled as 4,76 mm (3/16") but they are the exact same parts from the same company that you get elsewhere labeled as .187!
On the back of the terminals is stamped ETC
aficionado2:
The cheapest I found them was at MCM Electronics. so I got 6 packs of 100. Here is the link : http://www.mcmelectronics.com/Home/level_5.jhtml?PRODID=16058&SKUID=15303
By the way, I have been reading the forum for a while now but this is my first post. Hello.
MinerAl:
Siris,
I politely disagree.
There's no play in these at all. Unless I have freak switches, which is possible since i didn't get them from Happs, these are .187s that I got at Wal-Mart.
rock345:
I'm goign to go check out Napa today. I used .250 before but they keep on falling off. So I'm going to go with .187 and hopefully it will all look much neater. After all when I post my website I don't want to be embarased by a sucky wiring job. Thanks for the heads up on Napa.
Siris:
MinerAl,
You could be correct, All I've ever found a Wal-Mart are .250 though. ???
