Author Topic: I Suck Because I'm New  (Read 2818 times)
Arcane Arcade
  • Last login:August 15, 2006, 12:00:49 am
« on: June 20, 2006, 09:28:37 am »
Ok, now I'm having a problem that's going to make me look like a complete idiot. Could we possibly skip all the newbie taunting that runs so rampant and almost every other message board on the 'net?
I downloaded MAME32 a couple times now and I can't get the damn thing to load on my computer. I've unzipped it and even tried redownloading. I've used other emulators before and have never had this much trouble. Can someone out there help?
Effayy
  • Last login:August 18, 2006, 02:09:07 pm
  • Slowest....Cab Builder.... EVER.
Re: I Suck Because I'm New
« Reply #1 on: June 20, 2006, 09:44:22 am »
Don't worry, we'd be happy to help.  Everyone was a Newbie at one point, y'know. :)
In order to help, though, we,d need a little more info.  When you say it won't run, at what point does it cause you an issue?  Will MAME32 not load up at all, or is it when you try to load a game?
- FA
PS.  You may end up seeing this thread moved to the software forum.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: June 20, 2006, 09:55:51 am »
noob!
seriously tho, more info.  Maybe post your text mame.ini
Let us know your rom directory (e.g. C:/mame/roms)
your mame.exe directory (e.g. C:/ArcaneJunk/emulators/mame/mame.exe)
and stuff like that.
also what operating system are you using, what version of mame, what version of roms, etc?
MYX
    • MYX Digital Blog
« Reply #3 on: June 20, 2006, 10:18:34 am »
Noob!  ;)
Timoe, If he is using MAME32 is the INI necessary? This sounds like more of a comand line MAMEWah type thing.
you should be able to unzip the download. Keep all the folders inside the MAME32 folder
If you want to make a shortcut for the exe this is fine.
Place all your leagally obtained ROMs into the ROM folder.
You should be good to go. MAME32 should handle the rest.
PS... If you decide to use 49 way joys or LEDWiz use PowerMAME32.
« Last Edit: June 20, 2006, 10:26:12 am by MYX »
M    Y    X
JONTHEBOMB
  • Last login:October 20, 2019, 12:08:18 am
  • BOOM!!!!
« Reply #4 on: June 20, 2006, 10:21:00 am »
This site may help you now or in the future:
http://www.mameworld.net/easyemu/mameguide/mameindex.htm
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #5 on: June 20, 2006, 10:23:55 am »
Noob!  ;)
Ah, good point (mame32).  But copying the text from the ini is the only way to know what options he's selected from the GUI.   Yes?
(stinky nitpicker)  ;D
Arcane Arcade
« Reply #6 on: June 20, 2006, 10:52:05 am »
Thanks for all the help. I'm glad to see that (at least) some of you aren't like the ---daisies--- on pretty much all the other boards I've been to in the past.
I think I wasn't descriptive enough in my original post. I can't even install MAME on my computer. I have no idea what the problem could possibly be.
ahofle
    • Arcade Ambience Project
« Reply #7 on: June 20, 2006, 10:56:14 am »
Well you're still not descriptive enough.  What exactly happens when you run the self extracting executable and install MAME32?  Are you getting an error msg?
Arcane Arcade
« Reply #8 on: June 20, 2006, 11:15:12 am »
Absolutely nothing happens. That's why I'm so confused.
Could someone out there send me a link to where you got your version of MAM32? I'd like to try to download iot from a different site. Maybe there was something wrong with the server ... or maybe I did something wrong somehow ... I don't know ...
cdbrown
  • Bowowow
« Reply #9 on: June 20, 2006, 11:21:23 am »
Where'd you try and download it from?
Try here
http://www.mamemirror.tk/
and get the one that says just mame32
the filename is mame32b.106.exe
« Last Edit: June 20, 2006, 11:22:59 am by cdbrown »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #10 on: June 20, 2006, 11:32:28 am »
Welcome.
This board is ENTIRELY unlike any other board you were at in the past.
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
« Reply #11 on: June 20, 2006, 11:52:51 am »
If you click the icon, and then nothing happens, you might have a bad download (guessing)...try downloading again from the site cdbrown suggested.
We're not trying to be difficult here...but "nothing happens" doesn't give us a lot to go on...try downloading again, then installing, and let us know what happens.
We'll get ya fixed up... :cheers:
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
MYX
    • MYX Digital Blog
« Reply #12 on: June 20, 2006, 11:56:38 am »
True...true... Sorry to sound cliche, but...
were all here cause were not all there  :dizzy:
When you download the zipped file, and you open it, is there then a few folders and a couple of other bits and pieces?
Are you using a Mac?
If you do have stuff in the unzipped folder and you are not using a mac, look for the mame32.exe
It does not go through an install like MS Word where you go to an install screen and you see files copying and stuff, it is more like you just start a program and it goes and that is it.
M    Y    X
Arcane Arcade
« Reply #13 on: June 20, 2006, 12:05:30 pm »
Success!!! .... well, sort of. I got the MAME program to work, but now I'm having problems with the only ROM I have at this point. I downloaded WWF WrestleFest from romnation.net.
God, I suck at this.
Could someone reccomend some good ROM sites, while I work out my lastest setback?
Also, I know I am VERY far off from this, but will other emulators work in a custom MAME cabinet?
Lilwolf
« Reply #14 on: June 20, 2006, 12:12:08 pm »
Asking for rom download locations is against the rules... I believe the site you have now is probably fine (I never used them).  Better chance that you are missing more files.
In mame32 there is a way to audit your roms (right click on the game??  under properties??) this will tell you if your missing more files.  I bet your missing the parent rom.  Parent roms are usually the latest version of a game.  Then there are child roms with only the changes from the parent roms (usually much smaller because one version of a game to another they only make small changes)
btw, you might want to spend some time at easyemu (www.mameworld.net/easyemu I believe).  GREAT site to answer all questions (other then rom locations)
Good luck...
« Reply #15 on: June 20, 2006, 01:57:46 pm »
Being a noob is one thing. Being a noob who hasn't read the FAQ, or the rules, and wanting your hand held through something as complex as mame cabinets, roms, an mame32 is entirely something else.
What you  need to do is do a lot of reading. Not a little, and not just what other people are posting. There is a lot of trial and error with this hobby. Coming on the board and saying "Mame32 not working - help!" doesn't do us any good at all. Promoting illegal activing? Also not good! You can't come on here and ask for roms. It says it in the 3rd post thats a sticky. Check the FAQ and come back with some intelligent questions and I'd gladly help.
Call me an ogre if you want, but the method you are pursuing to become informed on this hobby is going to be much slower than actually doing some reading on your own.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #16 on: June 20, 2006, 02:13:23 pm »
Agreed.
Does that make me a daisy ?  >:D
Also read through the BYOAC Wiki.
Cheers.
« Last Edit: June 20, 2006, 02:15:04 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
MYX
    • MYX Digital Blog
« Reply #17 on: June 20, 2006, 02:19:20 pm »
orge  ;)
Yup, No peaksay boutaay teh OMRays Oodday!
Bad BYOAC fu
Try to find a common game for starters make sure it works. Then try for the more obscure stuff.
As to leapiniew's remarks...Yup, there is a ton to read. Kiss yer family n kids goodbuy for a while and start to pour through the docs. Then you will be strong in the Fu.
M    Y    X
shardian
« Reply #18 on: June 20, 2006, 02:29:35 pm »
Yeah,
I've been reading anything and everything, messing around in software, buying loads of used crappy arcade stuff, all for the last few months.
After all of that, I am still a newb that knows next to nothing.  ;D
This means that you have a LONG way to go.
This hobby is my best friend and my mortal enemy at the same time.
A few tips from someone fresh in the game for a newb such as yourself:
Don't post a new thread about a very general question.
Always try several searches here and on google before posting new thread.
Don't get cocky and insult people whom you may need help from later on.
And lastly, (from personal experience) no matter how experienced you are on other forums, that don't mean jack on here. You are still a newb.
Arcane Arcade
« Reply #19 on: June 20, 2006, 02:44:07 pm »
I've realized that I apparantly jumped the gun, if you will. And for that I'm sorry. I just got a little over excited aboutmy new found hobby. But in my defense, I did read the FAQ and the EasyEmu site. When I originally installed MAME32 nothing happened. Literally. I installed it, and there were no folders, no files, no MAME, no nothing. But I have sinced worked that problem out, thanks to the help of all of you. (I just want to say thank you to those of you who were nice enough to help me out)
Also .... I didn't think I was insulting anyone. I'm not sure how anything I said could be taken as an insult, but if someone does feel that I've insulted them, then I'm sorry for that too. And as far as my mentioning other boards (and the topic of this thread), that was just a joke. I was making fun of all the people who give the newbies ---steaming pile of meadow muffin--- just because they're new.
So now I'm off to study up. I'll try not to bother anyone with questions like this unless I absolutely have to.
But one more thing before I go. I didn't know that you couldn't ask for ROMS here. That was my fault. I should have read the rules. Again, I just got a little over excited. But is it ok to ask about my virus conerns about downloading ROMs?
Havok
  • Trade Count: (+17)
« Reply #20 on: June 20, 2006, 02:45:15 pm »
Make sure to put your legally obtained ROM in the ROMS folder, where you installed\unzipped Mame.
Also, buy this:
Arcade Bible
Read it!
Then read it again!
Some of the info is starting to get dated, but most of it will be relevant for all time...
Oh, did I call you a n00b?
« Reply #21 on: June 20, 2006, 02:52:36 pm »
Also .... I didn't think I was insulting anyone. I'm not sure how anything I said could be taken as an insult, but if someone does feel that I've insulted them, then I'm sorry for that too. And as far as my mentioning other boards (and the topic of this thread), that was just a joke. I was making fun of all the people who give the newbies ---Cleveland steamer--- just because they're new.
Good luck and happy Arcading... is that a word? Do everyone a favor and keep a log of your progress and post it in the project announcements page. I love reading those things.
shardian
« Reply #22 on: June 20, 2006, 03:04:34 pm »
Also, buy this:
Arcade Bible
Read it!
Then read it again!
Jeesh! How could I forget mentioning that I read that book cover to cover before posting here the first time! My apologies Saint for leaving your masterpiece out. ;)
MYX
    • MYX Digital Blog
« Reply #23 on: June 20, 2006, 05:46:15 pm »
God knows, but he still loves you.
I don't think that shardian was saying that you insulted anyone here, he was stating some good rulz for noobs.
Enjoy the excitment, this is an awesome hobby, labor of love, addiction whatever. It is why we are here too. One day you will read a post from some poor noob and you too will say... "listen here lad, Yer a Newb! so READ!"
As to the ROMS, you hit a hot button. As you may or may not know, It is not legal to posess ROMs you do not own. Thus, not a good topic to discuss on this board. If the topic comes up and is discussed, the great and powerful Saint will part the clouds and come in wooshing in on wings of little birds and strike lightning into the evil thread and cast it into the place that threads dare not speak about. POST HELL!
* MYX  goes off and shivers at the thought.
M    Y    X
SirPeale
  • Green Mountain Man
« Reply #24 on: June 20, 2006, 07:14:51 pm »
Welcome.
Hey, that's true!
Now...STFU, STFD, and RTFM, N00b!
(I kid!  I kid!)
Arcane Arcade
« Reply #25 on: June 21, 2006, 02:51:36 am »
I feel like such an ---uvula---. I was unzipping my ROMs and putting the unzipped files into my MAME roms folder.
Like I said ... I suck because I'm new   :P
MYX
    • MYX Digital Blog
« Reply #26 on: June 21, 2006, 09:30:22 am »
eh hem... NEWB!
sorry had to be done.  ;)
M    Y    X
PCtech
« Reply #27 on: June 21, 2006, 05:28:41 pm »
I learned early on, you can't take anything said personally.  Also, after you've been here awhile, you'll see the same questions posted over, and over, and over, and while it's understandable, many of the folks here (not me) have gone to considerable trouble to put together FAQ's, Books (Saint's Project Arcade book... :notworthy:, is the best thing a newb can do for him/her self), and many walkthroughs.
Plus it's a little like an initiation (Thank you sir, may I have another). >:D
I've been posting here for almost a year, and on another board for about the same time, and I'm still a Newb.... :banghead:
But the majority of these folks are great, and will be more than willing to help....after you've done a little searching of the forums, or FAQ's.
And, asking about ROMS, will get you more grief than it's worth (THAT part you gotta figure out for yourself)
Good luck, and stick around, you'll love it.
