Author Topic: Ms. Pacman / Galaga Reunion 4-way stick problem  (Read 2270 times)
shardian
« on: June 19, 2006, 11:28:19 am »
I have a new Ms. Pacman/Galagareunion stick that has a problem. When I move straight from left to right, or from up to down, The stick "pops" loudly. The motion is VERY clunky and is not going away with time. I have taken out the stick, and looked it over. It appears there is a grommet (I guess that is what it's called) inside the sealed case that is causing the problem. Is there anything that I can do to fix this?
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Ms. Pacman / Galaga Reunion 4-way stick problem
« Reply #1 on: June 19, 2006, 01:42:22 pm »
No grommets in there.
A Reunion (or Super) will clunk if the pivot cone is installed wrong- Is your cone installed on the handle above the joystick base, with the wide end facing down?
shardian
« Reply #2 on: June 19, 2006, 03:46:33 pm »
Yes, I believe I remember looking up into the joystick and moving that part around. It did appear that the lip part of it was facing down. If I pressed up on it and then moved it around, the clunking went away. How do I remove that part to turn it around?
Kremmit
  • - AHOTW -
« Reply #3 on: June 19, 2006, 07:05:24 pm »
Remove the e-clip, pull out the handle, flip the pivot cone, replace the handle, replace the actuator, replace the e-clip.
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
« Reply #4 on: June 19, 2006, 07:12:21 pm »
Yep, its the pivot cone.  You've got it in upside down.  I only know because I did the same thing at one point.
Good luck!
Kremmit
  • - AHOTW -
« Reply #5 on: June 19, 2006, 11:23:07 pm »
Heh.  Me too.
shardian
« Reply #6 on: June 20, 2006, 07:55:42 am »
Ok, I took this thing completely apart and played around with it for awhile. I have determined that what is making the clunking is the spring grabbing onto the plastic shaft it sits on. It was assembled correctly in the first place. Now what?
shardian
« Reply #7 on: June 20, 2006, 08:59:42 am »
I am thinking about selling this and getting a mag-stick-plus...
Kremmit
  • - AHOTW -
« Reply #8 on: June 21, 2006, 01:27:12 am »
Something's not right, or it wouldn't be doing that.
Have a look here.  http://www.happcontrols.com/joysticks/super_joy_e.htm
(It's a Super, but they're basically the same as a Reunion.)
Is the spring grabbing the part labeled 96-1421-00, or is it grabbing the raised center section of the bottom plate of the joystick body?
shardian
« Reply #9 on: June 21, 2006, 09:35:20 am »
The spring itself is catching on the plastic that comes down from the TOP of the main joystick body. I have highlighted the area in the below pic. As far as i can tell, the clunk is caused by the spring hopping up on the lip of the plasticand getting snagged. I am thinking that I could sand tis plastic down, but think I should have to. You know what I mean? If I lift up on the joystick handle and move it around, the clunk doesn't happen.
Dervacumen
  • Last login:February 13, 2019, 10:11:11 pm
  • Home of Three Squares dice game
    • Beaker Games
« Reply #10 on: June 21, 2006, 01:53:50 pm »
I had the same issue with both the Reunion and the Super.  Since I had an unopened Reunion stick, I compared the thunking one and the unopened one, and found that I had put the dumbell shaped grommet on upside down.  I think that grommet slightly changes the height the stick assembly rests in the body, and that caused the spring to stick.
Bringing to life a child's imagination.
shardian
« Reply #11 on: June 21, 2006, 02:00:23 pm »
I put this one together in every configuration possible. The thing didn't even work any other way. I am convinced it is assembled correctly. Maybe I could put in a washer or something above the bottom e-clip to tighten things up a bit. I'll take some pictures and video tommorrow and maybe we can figure this thing out.
Dervacumen
    • Beaker Games
« Reply #12 on: June 21, 2006, 09:30:21 pm »
Man, I'm sorry, 'cause that's a major pain in the ***.  Nothing bites worse than a jstick config that should work but doesn't.
You may have a lemon.
shardian
« Reply #13 on: June 23, 2006, 01:26:55 pm »
 :banghead:
Well, I went to do some video/pictures yesterday. After doing some before shots, I started to take things apart. I got to the pivot cone, and noticed that it was upside down. I decided what the hay, and flipped it over again. put it all back together and Voila! It worked. I know for a fact I flipped that dang thing around before and tried it. I must have switched 2 things around because it got worse then. Thank you all for your help. I can now finish my 4-way vertical cabinet in peace.
« Reply #14 on: June 23, 2006, 02:09:25 pm »
damn...
Way to hang in there!
