Author Topic: Glue for Lexan Sandwich  (Read 1158 times)
rdagger
« on: June 18, 2006, 02:47:16 pm »
I need to sandwich a few pieces of 1/8" Lexan together to make a 1" thick piece.
Can anyone recommend a glue that will leave the Lexan transparent?
Can I mix plexi in between the Lexan pieces to save money?
Re: Glue for Lexan Sandwich
« Reply #1 on: June 18, 2006, 06:18:39 pm »
I'm really curious as to the reason you want a 1" thick peice. Whats the total overall dimensions your looking to get?
Capthowdy
  • Last login:April 13, 2015, 03:33:18 pm
« Reply #2 on: June 18, 2006, 06:32:54 pm »
I'm pretty sure he wants to reenact a scene from Karate Kid Part 2!
rdagger
« Reply #3 on: June 18, 2006, 07:23:39 pm »
I'm trying to perfect my volcano button lens casts by building a vacuum chamber.   The Lexan is for the chamber's view port which must withstand a vacuum of 30 inches Hg (762 Torr).  One inch thickness might be overkill, I probably could go 1/2", but I haven't found a good method to calculate the minimum thickness to avoid a catastrophic implosion.
vrf
  • Last login:October 13, 2017, 10:11:54 pm
    • Pixelbox
« Reply #4 on: June 18, 2006, 09:09:48 pm »
I've also been looking for a good acrylic glue. Tap plastics has some good stuff available.  They say they dry "optically clear," so it might be what you're looking for. (Although, for my cab, I'm not really looking for clear, just really strong.)
http://www.tapplastics.com/shop/category.php?bid=21&
knohbody
  • Last login:January 31, 2019, 11:49:53 pm
« Reply #5 on: June 19, 2006, 02:28:30 pm »
For acrylic, make some acrylic cement out of leftover plexi and acetone.
http://guides.pimprig.com/modding/diy_acrylic_cement.php
Have no idea if it works with Lexan, though.
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #6 on: June 19, 2006, 05:45:54 pm »
Methylene Chloride is good stuff (I think that's the name).  Looks like water.  Dries clear.
I should also mention, it's also very bad for you.
« Last Edit: June 19, 2006, 05:48:06 pm by Nannuu »
Next I'll be on fries, and that's when the big money starts rolling in.
rbarr110
  • Last login:September 25, 2023, 04:02:41 pm
  • I already built my own arcade controls!
« Reply #7 on: June 19, 2006, 06:20:09 pm »
I have glued acrylic before, as long as the glue is applied evenly, it will look fine.
What I had tried before was just glueing in dots at corners of large pieces, you could see the glue at the perimeter edges of the glue dots.  On smaller pieces I applied glue on the entire piece and could not "see" the glue.  It may be difficult to get a completely clear piece laminated together if it is a large window.
