Main > Main Forum
Is this system worth using for Mame cab?
Pages: << < (2/2)
DeathMonk:
I built an AMD XP 2100+, ASUS A7N333, 256MB PC2100 and a mid-tower 300W for $300 shipped.
Chris:
I used a motherboard with onboard sound and onboard video, because I didn't want a case in the cabinet, so I didn't want any cards.  The onboard sound is fine, but the onboard video does slow things down, and I did add extra memory to compensate for the shared memory loss.
Not all onboard audio and video is equal!  ATI's onboard chips are fine, whereas S3's suck.  Some onboard audio is hardware based, and some uses the software AC97 codec.
Whether the system is sufficient or not depends on what you plan to play, but definately plan on adding at least another 256 MB of RAM if you get that system;l Crucial has it for $35 right now (see http://www.crucial.com/store/listModule.asp?module=DDR+PC2100&cat=RAM&package=184-pin+DIMM&submit=Go).
The 6 USB ports on that system are good for MAME, though... mine has 4, and 3 are already used (lightgun, trackball, USB network) with the 4th used for keyboard when configuring things.  I'll need to add a USB hub if I put in a second lightgun (if u_rebelscum is successful making it work)...
The motherboard specs for that machine are at http://www.machspeed.com/mfp533.htm, but it doesn't say which onboard chipset it uses.
--Chris
creatine28:
Great!  Thanks a lot for everyone's input! My current system is a Comaq 667 mhz Celeron with 300+ mb's of ram.  I had issue's with the on board sound and video through  DOS, so I bought a cheap SB16 PCI card and a cheap Ati Rage fury video card and everthing works well.  I just need to get a faster system to run some of the newer games.  I can run quite a few of the games(Got a full .65 set), but the ones that seem to slow down are the games like NBA JAM, Mortal Kombat 2....etc and of course the CHD games.  Of course my hard drive is pretty well filled up, so I need a larger one soon!
Pages: << < (2/2)
Go to full version
