Main > Main Forum
Plunge Router with hole saw bit
Pages: << < (2/4) > >>
shmokes:
This website is great.  Not only do you all offer great advice on how to build an arcade cabinet you have possibly saved my life  :-\
kspiff:
Whoa.. I had been wondering if they made drill guides like that.. maybe I'll get one of these and skip the drill press.. then again a decent drill press can be had for a little over 2x as much if I can catch a good sale.. hm.. hard choice :-\
ErikRuud:
Yes, they have had drill guides like that for years.  For a cab builder those guides maybe more usefule than a regular drill press.  My drill press, like most of the lower priced ones, cannot reach all the places on a CP that you will want to drill holes.  A drill guide on the other hand can be used anywhere on the CP.
I did drill all my holes by hand with out a guide. My drill has a bubble level on the end to help keep the holes straight.
Brax:
--- Quote from: shmokes on March 06, 2003, 02:43:52 pm ---Could I use a hole saw bit in a plunge router to make it work like a drill press for perfectly straight cuts?  I suppose the bit might not even clear the opening in the base of the router, but if it would is there any reason to avoid using drill bits in a router?
While we are at it can anyone tell me what size hole saw saw to use for buttons and joystics?  I'm sure I can get this information from previous threads so I would appreciate at least an answer to the first question if anyone has an idea as to whether this would work.
Good freaking god! Thankfully it's already been mentioned but DON'T DO IT!
Don't ever, ever, EVER, E V E R put a bit into a router that wasn't designed to be there!!!!! Holy crap.
I know this hobby collects quite a diverse demographic considering it marrys several very different hobbies. Woodworking, electronics, hardware, software, etc. For those of you that aren't woodworkers, don't ever put something in a powertool that wasn't designed to be there!!!!!! Just don't do it!
You'll look pretty stupid having, "He died while making a Pac Man cabinet" on your tombstone.
Pixelhugger:
KSPIF- if you've got the extra $50 go with the drill press IF it'll reach where you need it. (I imagine the smaller $100 presses are more limiting in how far they'll reach tho). That really is a concern, measure it first of course.  The hand held guide is exactly that - a guide. It can definatley be better than guiding by hand alone but it's no where near as dead on precise as a drill press.  ;D
Go to full version
