| Main > Main Forum |
| A newb and his panel... |
| << < (2/2) |
| syph007:
Ah ok. The spinner could move to one side. The right makes most sense I suppose. I put the spinner in the middle so it could be operated by either hand. In tron, you'd want the left had there, right hand on p2 topfire. For any other spinner game, like arkanoid, I'd want my right hand on the spinner, left hand on p1 buttons. Do most poeple use a spinner with the left or right hand? I inteded the top fires to be used by the right hand only, so button access was not something i considered. Is there a game that you'd want a topfire stick and access to buttons? I assumed once you were going to use buttons you would just used the normal stick. The only real purpose of the topfires for me was so I could play tank games by not having to add a 2nd panel. |
| ahofle:
I basically took the same approach as you with my panel. Playing games like Assault, Battlezone, and Tron were mandatory for me. My panel has the topfires a little higher than in your diagram however (I wanted to be able to rest my hand without it pressing any buttons). I've been pretty happy with it, and the spinner is sufficiently far from the trackball to not cause any issues in Golden Tee. Having a highball trackball also seems to help this. Just move the trackball as far down as possible, and move the spinner up a good amount and you should be fine IMO. My ultimate goal is to replace the 8way topfires I have (where did you get dynamically switchable 4/8 way ones???) with analog sticks like THIS with tank/tron style handles. That would give me pretty much perfect controls for Tron, and allow easy switching between 8, 4, and even 2 way for tank games. Oh, and one other thing...Make sure you mock this up with the controls mounted loosely in some stiff cardboard and try it out for yourself. That's the best way to tell if you'll like it. |
| 19rjs99:
--- Quote from: syph007 on June 12, 2006, 10:55:01 am ---Is there a game that you'd want a topfire stick and access to buttons? --- End quote --- Ninja Gaiden uses a topfire and 2 buttons for each player. You could just use 3 buttons though. |
| syph007:
ahofle, The top fires I was thinking of using were the groovygamegear ones. I like the fact that they were top switchable. http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=65&products_id=192 So you have your sticks offset too then... how does it feel for tank games having the right one higher up? That was my only concern, but I like that idea better than a wider panel. I have been watching those new ultimarc 360 sticks as well, but I've kinda already made up my mind on what I want to use, and I'm too impatient to wait for reviews long range use etc... |
| ahofle:
Actually, I use both topfires at the same time when playing tank games, not staggered like that (mine are even more 'staggered' than yours though). This way, they both have the same feel and are both level. I actually prefer the shorter throw of the topfires for games like Robotron too. Of course this eliminates 2 player simultaneous 2 stick games like Smash TV, but there are much fewer of those games (I usually just break out a USB gamepad for that anyway :-X ). Are there any 2-player simultaneous tank games? Vindicators comes to mind, but I can't play that anyway because you need two buttons on the sticks, not one. If you really want the topfires to be for each player's right hand only, I would personally line them up with the other sticks. I don't think a few extra inches in width would qualify your CP as having wings. ;D Thx for the link on the topfires. Those are pretty nifty, although they take up quite a bit of real estate with that mounting plate. |
| Navigation |
| Message Index |
| Previous page |
