Author Topic: will namco guncon for ps2 work with mame  (Read 6821 times)
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« on: June 08, 2006, 09:39:11 pm »
I am thinking of using guncons from a ps2 for mame, will they run or is this a waste of money.  thanks
Its easy to like someone,
If you dont know them very well.
mgmurrow
  • Newbie
  • Last login:June 09, 2006, 06:37:33 am
Re: will namco guncon for ps2 work with mame
« Reply #1 on: June 09, 2006, 06:32:15 am »
the guncon2 will work with mame and is a cheap way to go  tney are not the best guns but they do work    need wingun2pc drivers
tore-
  • Last login:June 11, 2014, 06:18:33 am
« Reply #2 on: June 09, 2006, 07:33:04 am »
It will only work with a CRT monitor, right?
Smog
  • Last login:April 30, 2007, 06:50:51 am
  • .357
    • How to make a cheap GunCon2 work on your PC
« Reply #3 on: June 09, 2006, 09:57:20 am »
mame works fine with Guncon2pc driver (http://xoomer.virgilio.it/guncon2) but unfortunately it has some problems with ORIGINAL guncon2 so If you plan to use an ORIGINAL guncon2 this topic should be of help to you :
http://freeforumzone.leonardo.it/viewmessaggi.aspx?f=66424&idd=117
read the messages from aljupi that seems to have experimented a lot with it.
ORIGINAL guncon2 can however be used with wingun driver under windows but this is not compatible with mame > 105 (but works with older versions) as long as I know.
CRT TV (or arcade monitor) is mandatory to use any guncon LIGHTGUN, but you can move to the CCD-GUNS (another technology) like EMS LCD TOP GUN that will allow you to use ANY kind of screen (CRTs, LCDs, PLASMA, projectors ... )
GunCon2PC Driver on http://guncon2pc.no-ip.org/
kiddk1
  • HAP KI DO
« Reply #4 on: June 09, 2006, 10:06:49 pm »
I have the two guncon2 that came with time crisis3,  the orange ones.  Do I just use the usb connection to hook them up and forget about the video cable.  I will try out your driver and see if it works.
Smog
  • .357
« Reply #5 on: June 10, 2006, 06:26:48 am »
Well Obviously no. It' won't work this way.
Take a tour on the wirings page on my site and you'll find the solution that better suites your needs.
kiddk1
  • HAP KI DO
« Reply #6 on: June 10, 2006, 10:36:28 pm »
it seems that I have to hack the gun to get it to work,  knowing me I will probably f**k it up.
Smog
  • .357
« Reply #7 on: June 11, 2006, 05:40:06 am »
hack the gun ? Really ? I' ve never suggested this in any of the 6 different connection scenario I propose on my site !?!
XtraSmiley
  • Last login:April 06, 2024, 09:29:46 pm
  • Kill the Big Dog
« Reply #8 on: June 11, 2006, 03:36:45 pm »
Oh great, I also bought the 2 orange Guncon2 with TC3.  They are not the best guns to buy?
If I want to use an Arcade VGA and a WG D92000 monitor, will I still need to "build a circuit"?  If so, does anyone sell already built ones?  I heard Andy from Ultimarc was going to sell some, but there is nothing on his site.
Thanks.
hearingprotectionBIGDOG@yahooBIGDOG.com
Kill the Dog man.
Smog
  • .357
« Reply #9 on: June 11, 2006, 06:11:45 pm »
building the circuit is not that hard, anyone can at least try
kiddk1
  • HAP KI DO
« Reply #10 on: June 11, 2006, 10:52:18 pm »
then maybe I am misunderstanding the directions on the page.  I got confused looking at the circuit and how to build it, still am confused.  help please.
