Author Topic: Need some help with nes emulater on mamewah  (Read 1448 times)
wallywalt
  • Last login:December 20, 2007, 09:13:14 pm
« on: June 08, 2006, 03:40:45 pm »
It seems everything is setup right. The emulater works fine out of mamewah, but when trying to open a game within mamewah this is the error I receive:
FCE Ultra Error
Error opening "=verifyroms"
Im using the latest version of mamewah and the nes emulater is fceu.
Here is my ini file, maybe its a setting in here?
### nintendo_162b10.ini (mamewah v1.61) ###
emulator_title                            Nintendo
### List Generation Settings ###
rom_path                                  c:\fceu\roms
rom_extension                             nes
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\fceu\fceu.exe
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path                        c:\fceu\videos
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path                                c:\mamewah\music
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
unclet
Re: Need some help with nes emulater on mamewah
« Reply #1 on: June 08, 2006, 04:22:31 pm »
Based on the INI file contents, it seems like you are using version "MameWah1.61", however, I noticed your INI file name is called "nintendo_162b10.ini" ..... so does this mean you think you are using version MameWah1.62b10 instead of the MameWah1.61 ?
Anyway, here is Jcrouse's INI file for FceUltra which I got fro mhis CPViewer site:
http://www.emuchrist.org/cpviewer/downloads/nintendo/nintendo_162b10.ini
You will notice it is recommended to use FceUltra as follows:
c:\fceu\fceu.exe {8.3[rompath]\[name].[romext]}{dosbox}{safelaunch}
« Last Edit: June 08, 2006, 04:25:32 pm by unclet »
wallywalt
« Reply #2 on: June 08, 2006, 04:38:21 pm »
I thought 1.61 is the latest version, I can't find anything more recent.
That ini is the same one i was trying to use, but when i start mamewah it changes all the settings to the following: (this is getting frustrating  :banghead:)
rom_extension                             nes
dat_file
nms_file
catver_ini_file
emulator_executable
movie_artwork_no                          1
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
scr_file
ipc_file_or_path
app_1_executable
app_2_executable
app_3_executable
auto_launch_apps
lcd_fe_text
current_list                              0
unclet
« Reply #3 on: June 08, 2006, 04:43:38 pm »
MameWah is a good program but it can be very frustrating ..... I know .... I set up about 30+ emulators on it.   Editing INI files by hand gets tedious, but once you do a few then you will learn what it takes.
I decided to switch to the MALA frontend to test it out and found it to be everything I wanted.   Extremely easy and nice GUI.   Anyway, I was able to setup all my emulators in about 20 minutes.  As a result,  I would recommend trying MALA to see if you think it is easier.
Although, if you want to stay with MameWah, then you can get the Beta version here:
http://www.mameworld.info/ubbthreads/postlist.php?Cat=&Board=arcadeospc2jamma
Once the site opens, make sure the click the "-" button to collapse all the threads into a much more readable format.  You will then see the thread regarding MameWah1.62b10 .......
« Last Edit: June 08, 2006, 04:48:12 pm by unclet »
wallywalt
« Reply #4 on: June 08, 2006, 07:43:19 pm »
does anyone have a working ini for mamewah 1.61?  I get an error when trying to load the rom still, and i would like to stick with mamewah, I like it for mame and if i can get my other emulaters working that would be great.
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
« Reply #5 on: June 08, 2006, 08:15:03 pm »
Are all your NES roms zipped? The reason being is that your ini has the rom extension as NES. If it's zipped it should be ZIP instead.
I can't remember what the diff is between the ini versions but I have working 1.61 versions at home if you still need it when I get home.
Brad
wallywalt
« Reply #6 on: June 09, 2006, 12:00:20 am »
No, they are .nes files. That would be cool if you could post your ini, i'm not sure what the problem is on mine :/
8way
  • Last login:February 03, 2017, 05:52:21 am
  • This is my BOOM stick!
« Reply #7 on: June 09, 2006, 05:15:20 am »
OK all you have to do is copy and past this over your old ini and you should be all set. By the way are you using the hacked version fceu?
rom_extension                            zip
dat_file
nms_file
catver_ini_file
commandline_format                        {8.3[rompath]\[name].[romext]}{dosbox}{safelaunch}
movie_artwork_no                          1
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
scr_file
ipc_file_or_path
app_1_executable
app_2_executable
app_3_executable
auto_launch_apps
lcd_fe_text
current_list                              0
jcrouse
    • CPViewer
« Reply #8 on: June 09, 2006, 11:24:15 am »
Change {autodosbox} to either {nodosbox} or {dosbox}.
John
wallywalt
« Reply #9 on: June 09, 2006, 05:20:17 pm »
You are a genius 8way!!! Thank you a hundred times. Yes, I am running the hacked version.  I think it was my commandline_format that was giving me the error.  Now I'm gonna see if i can figure out how to use a different layout for the different emulators.  Thanks again!
unclet
« Reply #10 on: June 09, 2006, 05:24:19 pm »
You realize I gave you that same format in the second post in this thread ........ but I am glad you finally figured out you needed to use it   :P   hehe.
wallywalt
« Reply #11 on: June 09, 2006, 07:11:28 pm »
I guess i just needed more clarity  :banghead: Thanks for the help guys!
