Main > Main Forum
Best way to light an Orange Translucent Button?
MARINE1142:
It looks like just a board with an led on it, looks to me to mount on the bottom of the button. I think i can do that with just a superbright led and a resistor. but from reading on this people say that the lighting would be good from the bottom but outstanding from the sides and i m always looking for things that are outstanding. Has anyone lit this buttons from the side? I will keep looking around the forum for answers. Thanks for the reply.
KillerArcades:
I lit mine from the sides. Though I haven't come up with a wondeful "nylon nut" of a solution, I read about that idea and then scoured local hardware shops until I found a suitable alternative. I don't know if I can explain very well what I used, because I don't even really know what it's called - I found a clear "plastic" (most likely some form of nylon....?) semi-flexible tube that was in the water/plumbing/hose area of home depot. I used my PVC cutters to cut this tube into little rings about 1/2" thick and then just drilled two holes into it on opposites sides of the rings and slid this up over/around the button and then used the button's black plastic nut to screw it snugly into place along with the button.
The tube I found was just slightly greater diameter than the button itself, and it was thick enough to hold the LED's in place (a couple of my holes required a bit of hot-glue to help make sure they stayed put though).
:( Like I said, not sure if I'm doing a good job explaining, I'll have to take some pictures and post them on the web to explain it better, if you're interested in seeing, that is.
Timoe:
I am interested in seeing it ^
MARINE1142:
I am interested in seeing the pics also getting ready to lit mine here soon and want the best possable way of doing it. Also I got this high out put leds some think like 9000 mcd or 9500 mcd but the viewing angle is only 20 degree does and one see a problem with these monting them either from the bottom or two facing each other? the buttons are red and blue and was going to use white light on both.
KillerArcades:
ok, I'm actually out of town this weekend, too. :) on a business trip in Wisconsin. The good news is that I found out that there's an arcade auction up here tomorrow morning that I'm going to try to check out.
anyways, yeah, that could be helpful. take your time, I've got a "honey-do" list that's grown rather long since I just finished working on my first cabinet.... so it'll be a bit until I get going very much in earnest on my driving cab, I'm afraid. ;)
