Main > Main Forum
Help Out A Newbie
Pages: << < (2/3) > >>
theblt:
Well, what program should I use then?  ArcadeOS or somethin?
theblt:
Tiger-Heli:
--- Quote from: theblt on March 05, 2003, 08:59:12 pm ---Well, what program should I use then?  ArcadeOS or somethin?
I think ArcadeOS is only DOS-based.  I like EmuLoader, but it's very Windowsy.  For a true cab, I would recommend Lazarus or )p('s Emulaxian virtual arcade.  (Sorry I don't have links)
eightbit:
Use Windows its faster than Dos. Use WinXP if your PC is fast enough. Buy a keywiz for an encoder. Use Mame32 for a front end at least until you find something you like better. Lazaruz and emulaxian might be a little tough to configure when you add to it getting everything else to work.
Minwah:
IMO you should stick with DOS with your 333.  Use ArcadeOS and obviously DOS MAME.  Windows is pretty painful on a PC that slow...
When you upgrade, then goto WinXP and one of the FE's in the software section.
Good luck!
Go to full version
