Main > Main Forum
Can I use one Dual Strike for all hardware controls without using switches?
Pages: << < (2/2)
unclet:
OK, then I probably would just stay with using multiple Dual Strike gamepads like I planned instead.  I want all the controls to be active all the time so the player can simply pick which control they want to use and play....without having to switch the control on/off.   Basically, so my young children can play easier.....thanks for the info.
UncleT
eightbit:
You can use the same dual strike hack. Just install some kind of plug between the controls and the hack. I did this for between my ipac and m control panel.
Pages: << < (2/2)
Go to full version
