Main > Main Forum
Perfect 360s
Pages: << < (2/2)
SirPoonga:
--- Quote from: jets on March 05, 2003, 12:44:50 am ---I'd like to use the 5V pins on the J-PAC to power the perfect 360 josticks. I'm paranoid about being sloppy and having the ground pin make contact with the 5V pin. Does radio shack have a harness that'll easily plug into the pins? Also, should I connect the ground to the common ground for the other buttons or the the ground pin beside the 5V pins?
Thanks for your help.
I don;t have 360s, BUT you aren't going to have a large glob of solder.  Then you could use heat shrink tube to cover the pins afterwords.
Pages: << < (2/2)
Go to full version
