Main > Main Forum
Why are Trackballs so freaken expensive?
Pages: << < (2/3) > >>
brandon:
I've got several trackballs but they are all the big boxey looking ones that I think were made by wico.. They are all rusted inside and need new bearings and rollers.  The only rebuild kits I can find are for the Happs/ Atari trackballs...  Anybody know were I should look?
u_rebelscum:
Economies of scale, size of the ball, and high durablity ("arcade quality") demands, to name a few.
Economies of scale:
The more made, the cheaper per device it is to make.  Thus the ?200? a year arcade trackballs cost more per than if ?10,000? were made, on the generic mice scale.
Example why: Even before a single trackball or mouse device it made, molds must be consturcted.  Molds cost thounds of bucks.  $2000 divided by 200 trackballs =  $10 per TB just to cover the molds (assuming two molds @ $100 bucks each, which is pretty conservative).  $2000 / 10000 mice = $0.20 per mouse to cover the molds.  (molds do last over a few years, but this is just an example)
Size of ball:
High quality, near perfectly round balls are hard to make.  The bigger the ball, the more it costs.  Compare a 3" TB ball to a 1/2" ball used on a mouse.  The cost is not linear.
Arcade quality:
Arcades quality equipment need to be able to survive a lot of pounding.  PC devices don't.  You pay for the increase in quality.
And high quality PC trackballs can cost more than arcade TBs.  Kensington Expect Pro & Turbo Pro Trackballs (2 1/4") cost ~$100.  You can get ps/2 3" betson trackballs for ~$80, arcade wired wico 3" costs ~$50, and wico/suzo 2 1/4" trackballs cost ~$25.  Shop around.
Rahzel:
My brain hurts
rampy:
--- Quote from: brandon on March 04, 2003, 09:13:18 pm ---I've got several trackballs but they are all the big boxey looking ones that I think were made by wico.. They are all rusted inside and need new bearings and rollers.  The only rebuild kits I can find are for the Happs/ Atari trackballs...  Anybody know were I should look?
they *may* be interchangeable...  the real bob roberts is real good at helping via email and he probably has a set of rollers/bearings that'll work...  *shrug* ymmv but that's where I'd look anyways...
rampy
Minwah:
Trackballs are dirt cheap, if you've ever taken a look at Happs analog joysticks.
And you'd better win the lottery for their yoke  :o
Go to full version
