Main > Main Forum
Laminate question
<< < (2/2)
CitznFish:
--- Quote from: Frostillicus on March 04, 2003, 11:18:33 am ---There's a step by step with pictures HERE .
double 'http:// in the URL..  this one is correct:  http://www.cybertechdesign.net/mameroom/ultimatearcadeII/tip4.htm
Nervous:
One other thing to consider is the glue: I've had good luck with the Formica brand water soluable stuff.
It actually seems to work better than the non-water sol compounds, and the fumes won't kill you either...  :)
SNAAAKE:
best way in my opinion,
You laminate the whole thing first with contact cement and let it dry for atleast like 2 hours then carefully drill with spade bit.A holesaw might be better then spade bit but i didnt have any problem..just built an all laminate couple of days ago.came out allright looking..
hunky_artist:
I know this is an old thread... but does anyone in the UK know where you can GET laminate?  ???
I've had no luck whatsoever
Tailgunner:
--- Quote from: hunky_artist on June 10, 2004, 01:49:58 pm ---I know this is an old thread... but does anyone in the UK know where you can GET laminate?  ???
Check with kitchen cabinet shops in your area. You could also check the manufacturers websites (www.formica.com or www.wilsonart.com) and see who's their UK distributor. Call/e-mail the distributor and they'll gladly point you towards a retailer.
Navigation
Message Index
Previous page
Go to full version
