Author Topic: trackball help  (Read 1064 times)
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
trackball help
« on: May 20, 2006, 05:30:32 pm »
I have the happs 3" trackball installed via ps/2 optiwiz, I have a ps/2 to usb adapter, the frontend recognizes the TB but not the actual games,  I have read and searched and tried some of the advice given but nothing worked.  I have the mouse set to 1 and for trackball_device I tried these options:
-trackball
mouse 1
mouse2
any help would be great, thanks  I should mention that I have a usb mouse plugged in that is used in windows.
here is my current mame.ini for input devices
### Input device options ###
mouse                   1
joystick                1
lightgun                0
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.30
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         keyboard
digital                 none
Its easy to like someone,
If you dont know them very well.
JLR2000
  • Last login:February 18, 2021, 02:49:16 pm
  • There is NO Sanctuary...
    • WWW
Re: trackball help
« Reply #1 on: May 20, 2006, 11:19:27 pm »
Did you plug the PS/2 Optiwiz into the PS/2 port (no usb adapter) to confirm that works?  If so, why not plug it into the port it was made for?
kiddk1
  • HAP KI DO
Re: trackball help
« Reply #2 on: May 21, 2006, 11:05:04 am »
yeah it works, I just thought using usb may give me more options in the future and wanted to see if it would work.  I actually got it to work in golden tee by going into the input settings for the game and setting the analog x and y to the trackball, i just hope I dont have to do this for every game.  thanks
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
Re: trackball help
« Reply #3 on: May 21, 2006, 11:47:08 am »
After you hit TAB, select Input all games.  Set it once and it will be fine.
kiddk1
  • HAP KI DO
Re: trackball help
« Reply #4 on: May 21, 2006, 04:31:28 pm »
thank you.
RandyT
  • Last login:Today at 11:46:17 am
    • GroovyGameGear.com
Re: trackball help
« Reply #5 on: May 23, 2006, 09:28:21 am »
What kind of adapter are you using?  The Opti-Wiz requires only a passive (i.e. cheap, no electronics type) adapter and it will autoswitch.
RandyT
kiddk1
  • HAP KI DO
