Author Topic: New WinIPAC Version  (Read 2216 times)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
New WinIPAC Version
« on: May 16, 2006, 04:36:36 am »
I have just uploaded a new version of WinIPAC (The software used to design control panels and download custom keycode configs to I-PAC and J-PAC boards).
Improvements:
Even faster download. PS/2 takes approx 2 seconds, USB is instantaneous.
Timeouts when using with non-English keyboard settings fixed.
Improved error detection and reporting.
I-PAC VE board keycode assignment problem fixed.
Many small improvements in the GUI although the general look and feel is unchanged.
Available from www.ultimarc.com/download.html
Andy W
brophog
  • Last login:January 20, 2019, 03:49:41 am
Re: New WinIPAC Version
« Reply #1 on: May 16, 2006, 08:34:59 am »
Any changes necessary to the IPAC boards to use the new software?
AndyWarne
    • Ultimarc
« Reply #2 on: May 16, 2006, 08:41:59 am »
Provided the board is post Jan 2004, no change is needed.
Andy
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
« Reply #3 on: May 16, 2006, 08:50:08 am »
Is this for the mini-pac also?
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #4 on: May 16, 2006, 09:55:28 am »
So what about pre-January 2004
Quote from: saint
saint is all powerful.
Apparently he is.
jcrouse
    • CPViewer
« Reply #5 on: May 16, 2006, 10:10:07 am »
Andy,
I see no mention in the docs of the required "/program" parameter that was required to actually upload the IPC file from the commandline using the previous version. Is this not required now or were the docs just never updated when the guy wrote the last version of the software?
John
juggle50
  • Last login:June 25, 2022, 02:46:08 pm
  • Your either on the bus or off the bus
« Reply #6 on: May 16, 2006, 12:08:28 pm »
I'm confused. if I've got an Ipac pre 2004 should I upgrade the software or stick with what I got?  Thank you.
AndyWarne
    • Ultimarc
« Reply #7 on: May 16, 2006, 01:31:41 pm »
Pre-2004 boards should not upgrade, but keep existing software. These boards use the original WinIPAC software which did not have the panel design feature.
All Mini-PAC boards which have the on-board self-test LED can use this new software. Older boards without the LED need to keep existing software.
The method of sending an IPC configuration to the board from a command line is simply run the program as "Winipac.exe myconfig.ipc" etc. There is an optional "/verbose" switch which causes the GUI to display during command-line download.
A full list of command line options is displayed by running "winipac.exe /?".
Andy
GrantJ
  • Last login:March 12, 2009, 01:06:53 pm
    • ArcadeCabinets
« Reply #8 on: May 17, 2006, 06:06:38 am »
 :soapbox: I love Ipacs they are such a cool invention  :notworthy:
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
« Reply #9 on: May 17, 2006, 08:27:21 am »
Cool. :cheers:
Congui
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #10 on: May 17, 2006, 08:52:31 am »
Andy
Except that the old software does not work under Win2K.  The last time I wanted to reprogram my IPAC, I had to remove it from the cab and use an older PC to run the software.
American Laser Games Wrapper
O2em Rom Utility
jcroach
  • Last login:March 01, 2012, 09:36:56 am
« Reply #11 on: May 17, 2006, 10:10:40 am »
Very cool.  This always buged me.  It still worked great, but not ideally. Thanks!
