Author Topic: Way to tell if a cab's power supply is good/bad?  (Read 842 times)
payment_due
  • ---Probation---
  • Last login:August 19, 2012, 11:04:24 pm
  • ---Probation---
« on: May 14, 2006, 11:02:52 am »
I've got a cab that I bought from a guy that is a MAME machine, so obviously I don't use the internal supply for PCBs.
Does anyone know of a way to see if it still works, other than plugging in a PCB? I have none at the moment, and I'm a bit leery about asking my friends to borrow one of theirs because I wouldn't want to ruin it if the PS I have is bad.
The guy said he never used the PS because he bought the cab sans PCB and turned it into a MAME cab immediately. He said he assumes it works, but is not 100% sure.
Any help would make me do this:  :notworthy:
my MAMEcab progress blog: http://www.lealmedia.com/mame/
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 02:20:28 pm
Re: Way to tell if a cab's power supply is good/bad?
« Reply #1 on: May 14, 2006, 11:05:09 am »
use a voltmeter  ;D
Free VGA Breakout Cable
payment_due
  • ---Probation---
  • ---Probation---
« Reply #2 on: May 14, 2006, 11:19:07 am »
Thanks, what kind of power reading am I looking for though?  I know how to use a volt-meter, but I'm no electronics expert by any means.
SirPeale
  • Green Mountain Man
« Reply #3 on: May 14, 2006, 12:09:19 pm »
If it's a standard AC --> DC power supply, like a Peter Chou, the voltages will be marked on the tabs.  A PS can 'read' good, but if you touch the voltage adjustment pot, it may shut down.
Best way to test a PS is under load.  If you value your board, I wouldn't use it, though!  Find another way (like a heavy ceramic wire-wound resistor) to put it under load.
If it doesn't have the screw tabs, but has a molex wiring connector, standard wiring colors usually apply: black for ground, red for +5V, yellow for +12V.
payment_due
  • ---Probation---
  • ---Probation---
« Reply #4 on: May 14, 2006, 12:56:35 pm »
Thanks Peale.  I'll need to get my buddy who is studying to be an EE to help me out then.  I'm pretty sure the PS is fine, but I don't want to risk ruining a friends PCB, or mine when/if I get one.
SirPeale
« Reply #5 on: May 14, 2006, 01:15:37 pm »
If it's already hooked up and running, then measure away.
Unless the PS is giving you obvious signs of distress, you should be okay.
  • bloated capacitors
  • buzzing
  • hot
  • shuts down when you adjust voltage
  • voltage WAY too high/too low on check
