Main > Main Forum
Wingman Warrior Questions
Pages: << < (3/3)
Tiger-Heli:
Two of the joysticks should work in 98SE, but you would need either two gameports or a gameport splitter cable (or maybe a gameport--> USB adapter).
Regarding the spinner, I am not sure.
Multiple serial spinners are supported under WinXP using MAME Analog Plus or MAME 0.105 or later.  But this particular spinner doesn't work under XP.
Multiple USB mice (spinners) are supported under Win98SE using MAME Analog Plus or MAME 0.105 or later, but I don't think this applied to serial mice. . .
eastbayarb:
Tiger Heli,
I really only want to use my two WW's for the spinner (the stick I will hack in a dfferent fason). Just as long as I can have 2 spinners working n my CP, that is all I care about.  I already have 98SE on my MAME computerr, so al I need now is the correct settings in MAME to have them work properly. Then more will be done than said
Kremmit:
Ultimarc's old serial Opti-Pacs appeared to the computer as two separate serial mice, and that was in the days before XP.  IIRC, Andy used to advocate a special build of MAME called Emu+ (not Analog+).
For XP users, I was looking inside my Wingman Warrior a while back, and I noticed that the optics on the spinner were those weird 4-leg optics that made older Logitech mice un-hackable.  Which got me thinking that these optics may in fact be hackable to one of those same older Logitech mice.  If somebody has an old un-hackable Logitech mouse sitting around, I'd love to have a go at it.
eastbayarb:
can anyone tell me what settings I need to make in windows 98se/mame to get 2 wingman warrior spinners to work in mame?
Fozzy The Bear:
--- Quote from: eastbayarb on May 18, 2006, 11:20:46 pm ---can anyone tell me what settings I need to make in windows 98se/mame to get 2 wingman warrior spinners to work in mame?
Honestly... I really wouldn't bother with this. There really are better solutions than this. You're going to be throwing money away here.
To be very honest while these sticks were a solution a few years ago they are simply way too much hassle now and the spinner to be honest sucks in comparison to modern ones.
Best Regards,
Julian (Fozzy The Bear)
Pages: << < (3/3)
Go to full version
