Author Topic: Wingman Warrior Questions  (Read 4455 times)
eastbayarb
  • Last login:March 08, 2013, 12:15:06 pm
« on: May 14, 2006, 01:28:20 am »
I am getting a Wingman Warrior Soon that I wanna use with MAME. It is what I believe an analog joystick and has a 360 degree spinner. Info can be seen here:
http://www.compuvisor.com/logwinwarjoy.html
I have some questions on it:
1. Does there exist a Windows XP driver for it (searched here and on google but no luck).
2. Can I use 2 of these with my computer ? I wanna use 2 of these for 2 player racing/spinner games.
3. Is the joystick analog and can be use with analog MAME games?
4. Anyone here have one or two of these and have successfully configured it with MAME?
Thank you!
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Wingman Warrior Questions
« Reply #1 on: May 14, 2006, 02:29:59 am »
Doesn't use a driver..... Runs under the windows driver.
I hope you're not buying one specifically to use with mame... It's not a great stick in the first place, and certinly not great for mame.  If you're getting it for free then good luck. Otherwise, buy something else.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
eastbayarb
« Reply #2 on: May 14, 2006, 02:33:09 am »
I am buying the Wingman Warrior mostly for the spinner
are you saying that Windows XP will be able to use the throttle/spinner/analog stick on this Wingman Warrior?
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #3 on: May 14, 2006, 04:14:03 am »
I remember WAYYYY back in the day the Wingman Warrior was one of the best mame solutions our there. How times have changed.
Quote from: saint
saint is all powerful.
Apparently he is.
StuckInJapan
  • Last login:June 17, 2006, 07:53:12 am
« Reply #4 on: May 14, 2006, 12:44:38 pm »
Actually, this IS a quality stick, and was the best FPS controller in its day.
Have to agree though that it won't make a good MAME choice in Win2000/XP.
The Logitech site says:
The serial port connection for the WingMan Warrior is not supported under Windows 2000 or Windows XP.
Serial and game port devices are not supported by the WingMan software in Windows 2000 or Windows XP.  To use this device in Windows 2000 or Windows XP, you must use the gameport connection and the native Windows drivers.
Problem with this is that you need the serial connection to access the spinner.
With just the gameport connection, you're limited to a choice between
a joystick+hat switch or a joy+throttle.
P.S. it's an analog stick, remember playing MAME Star Wars with it a long time ago
« Last Edit: May 14, 2006, 12:48:06 pm by StuckInJapan »
eastbayarb
« Reply #5 on: May 14, 2006, 06:56:42 pm »
StuckInJapan,
I don't mind running Windows 98SE to use this.
I would like to know however, if I can use 2 of these on the same PC (along with a trackball or 2).
Gh0sty
  • Last login:December 04, 2019, 05:04:06 pm
  • flying Mame Player
« Reply #6 on: May 15, 2006, 04:49:47 am »
I have this Wingman Warrior running on Windows XP here,
Joystick works ok. I have a serial port and connected the
spinner to it, but like StuckInJapan said, the spinner dont work
in XP. I'm trying to find special software for connecting
& running harwdare trough the serial port in XP, so far no luck,
and i dont plan to install 98 again ;)
R
Gh0sty
eastbayarb
« Reply #7 on: May 15, 2006, 05:10:48 am »
I plan on running Windows 98SE...many have said it is good and preffer it. Or I may run XP and 98SE within it via VMware when I wanna run spinner games.
too bad the spinner isn't hackable to a USB solution
ahofle
    • Arcade Ambience Project
« Reply #8 on: May 15, 2006, 12:47:03 pm »
I still think it's one of the best controllers for playing Tron and DOT (other than the original controls of course).
eastbayarb
« Reply #9 on: May 18, 2006, 12:17:08 am »
Anyone know if 2 of these can be used on the same PC (with Windows 98SE), and what does the hat switch do? And what modifications to Windows/MAME do I need to get the spinner working correctly?
As far as the spinner/serial port in XP, maybe a serial to USB might work?
« Last Edit: May 18, 2006, 01:45:42 am by eastbayarb »
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: May 18, 2006, 09:45:57 am »
Two of the joysticks should work in 98SE, but you would need either two gameports or a gameport splitter cable (or maybe a gameport--> USB adapter).
Regarding the spinner, I am not sure.
Multiple serial spinners are supported under WinXP using MAME Analog Plus or MAME 0.105 or later.  But this particular spinner doesn't work under XP.
Multiple USB mice (spinners) are supported under Win98SE using MAME Analog Plus or MAME 0.105 or later, but I don't think this applied to serial mice. . .
eastbayarb
« Reply #11 on: May 18, 2006, 02:48:21 pm »
Tiger Heli,
I really only want to use my two WW's for the spinner (the stick I will hack in a dfferent fason). Just as long as I can have 2 spinners working n my CP, that is all I care about.  I already have 98SE on my MAME computerr, so al I need now is the correct settings in MAME to have them work properly. Then more will be done than said
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #12 on: May 18, 2006, 10:52:40 pm »
Ultimarc's old serial Opti-Pacs appeared to the computer as two separate serial mice, and that was in the days before XP.  IIRC, Andy used to advocate a special build of MAME called Emu+ (not Analog+).
For XP users, I was looking inside my Wingman Warrior a while back, and I noticed that the optics on the spinner were those weird 4-leg optics that made older Logitech mice un-hackable.  Which got me thinking that these optics may in fact be hackable to one of those same older Logitech mice.  If somebody has an old un-hackable Logitech mouse sitting around, I'd love to have a go at it.
« Last Edit: May 18, 2006, 10:54:50 pm by Kremmit »
eastbayarb
« Reply #13 on: May 18, 2006, 11:20:46 pm »
can anyone tell me what settings I need to make in windows 98se/mame to get 2 wingman warrior spinners to work in mame?
Fozzy The Bear
« Reply #14 on: May 19, 2006, 07:00:03 am »
Honestly... I really wouldn't bother with this. There really are better solutions than this. You're going to be throwing money away here.
To be very honest while these sticks were a solution a few years ago they are simply way too much hassle now and the spinner to be honest sucks in comparison to modern ones.
Best Regards,
« Last Edit: May 19, 2006, 07:34:08 am by Fozzy The Bear »
