Author Topic: MOD: Suzo Universal Inductive  (Read 24229 times)
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: MOD: Suzo Universal Inductive
« Reply #80 on: September 27, 2006, 10:51:16 pm »
I'll grab two meshballs.
Also, I haven't gotten any payment instructions from Kowal- what are USA buyers doing?
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #81 on: September 28, 2006, 04:48:13 am »
Please send money to Ponyboy (say him that this for me - kowal). When Ponyboy confirm payment I will send items. Yesterday I send 4 (four) to RobotoNut.
In akihabara I will order 5 october 2006, I wait for my salary only.
list:
4x Sanwa LB-35-MP (Meshball)
2x Seimitsu LB-39 clear bubbleball WHITE (Clear)
« Last Edit: September 28, 2006, 04:51:32 am by kowal »
Level42
« Reply #82 on: September 28, 2006, 08:54:44 am »
OK thanks Kowal ! As soon as you know the total (including the balls) I will transfer the money.
kowal
  • Suzo 4ever
« Reply #83 on: September 28, 2006, 03:23:14 pm »
First package has come to me. I will sum up cost then.
Grasshopper
  • Last login:November 08, 2023, 07:20:31 am
« Reply #84 on: September 30, 2006, 10:51:47 am »
Kowal, here is my provisional order for the Balltops (15 balls and 6 shafts):
4* Sanwa LB-35, Dark Blue
2* Sanwa LB-35, Red
3* Seimitsu LB-39 Bubble Ball, Orange
3* Seimitsu LB-39 Bubble Ball, Blue
3* Seimitsu LB-39 Bubble Ball, White
3* Sanwa JLF-PP1 dustcovers (2 per set)
Can you give me an approximate idea of the total cost? If it is too much then I may have to prune the order a bit.
Grasshopper
(p.s. please can you also confirm you have received the money for the shafts)
kowal
  • Suzo 4ever
« Reply #85 on: September 30, 2006, 12:01:22 pm »
Can you give me an approximate idea of the total cost?(p.s. please can you also confirm you have received the money for the shafts)
this very a lot of. I have this to think over
possible that ponboy has meshball and bubble ball.
yes confirm, money came :)
rolls rolex
  • Last login:November 07, 2007, 07:01:27 pm
« Reply #86 on: October 01, 2006, 10:58:32 am »
Hey guys, i'm building my first desktop control and came across this topic. I'm pretty excited about it and have been educating myself this last week. I know it's gonna turn into a rediculous hobby  ;D I'm searching for a red ball for an Omni basic and fell in love with that meshball  :applaud: Are these shafts still available and will it fit the Omni stick basic? I really hope i can join the club  :cheers:
Hey Kowal i think i left you an email, what a coincidence. I was browsing your great Polish site :)
« Last Edit: October 01, 2006, 11:05:06 am by monkeyman »
kowal
  • Suzo 4ever
« Reply #87 on: October 01, 2006, 01:59:04 pm »
foto handles
sorry only 4 inductive
« Last Edit: October 01, 2006, 02:13:44 pm by kowal »
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #88 on: October 01, 2006, 09:08:09 pm »
you can get a versa-ball shaft from groovygamegear.com, which fits the omni-stik basic. these versa-balls are threaded; i'm not sure if they're the same threads as the meshball.
to see my "Frankenpanel" and design notes, click here.
rolls rolex
« Reply #89 on: October 02, 2006, 12:03:10 am »
Hmmm let me ask ggg, thanks.
Kremmit
  • - AHOTW -
« Reply #90 on: October 02, 2006, 02:00:14 pm »
They're not.
Grasshopper
« Reply #91 on: October 07, 2006, 07:23:23 am »
Kowal, can you confirm that the Sanwa JLF-PP1 dustcovers can be used with your shafts?
kowal
  • Suzo 4ever
« Reply #92 on: October 07, 2006, 09:55:08 am »
yes it fit.
if you want larger washer (how J-stick),  you have to buy JLWPP1 but they do not fit they have wide openings. It it was it been possible was to buy JLW - PP 1 and additionally JLF CD.
Grasshopper
« Reply #93 on: October 19, 2006, 02:57:19 pm »
My handles have arrived.  :D Thanks Kowal.
First impressions are very good. I'll do some tests over the weekend and maybe post some pics.
Level42
« Reply #94 on: October 19, 2006, 03:52:55 pm »
Ok I'm completely in the dark about this. Kowal did the balltops arrive from Japan ?
If so please update me about total costs etc. Thanks.
RobotronNut
« Reply #95 on: October 19, 2006, 05:10:06 pm »
my handles arrived a while back. they look good, but it may be a while before i can give them a good test. i'll post results as soon as i have any.
kowal
  • Suzo 4ever
« Reply #96 on: October 20, 2006, 04:05:21 am »
they should arrive, to me soon.
RobotronNut
« Reply #97 on: November 15, 2006, 04:49:58 pm »
i finally got a test panel put together and tried my suzo inductives with kowal's custom balltop shafts.
the construction quality of the shafts is superb!
i played robotron a few hours and have concluded that, in their stock form, the suzo inductives are not well-suited to robotron. the problem is the little "bumps" that separate the 8 positions. after i'm past the early levels in robotron, i need to be able to make round, sweeping movements very quickly. i keep getting killed because i got "stuck" at one of the little bumps and couldn't get the joystick into the position i needed it to be in. my scores with my p360s are much higher than with the suzos.
IF you want complete smooth motion (no notches) out of your inductive, do the following:
Remove the plastic cover in the bottom.
Remove the circuit board.
Pop off the C-clamp Omega clamp from the stick, and take out the shaft.
Wrap a small piece of gritty sandpaper around your finger (grit facing outside ;)) and twist away where the shaft was until the bumps are no more.
Put it back together.
Voila!  Enjoy your new quiet, silky smooth inductive controller.
i'll give this a try.
and another small tip: if the joystick engages more quickly in one direction than the other, you can play with some of the other pots on the board and easily fix it.  I had one controller that kinda bothered me for a while and after i fooled with it, it's perfect.
one of my 3 inductives has one direction activated even when the stick is in its neutral, centered position. i'll try playing with the pots. do you know what the various pots control? i'd rather not mess up the trim of all the pots by randomly trying stuff...
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
« Reply #98 on: November 20, 2006, 11:01:42 am »
Unfortunately, i came down with the same problem recently.  I've had to make enough adjustments on these things that it might be worth it to really put together a comprehensive guide to the potentiometers...  I'll try to do it soon, but today is definitely out.  :)
and i wouldn't really worry about screwing anything up.  as long as you have something running where you can test the new limits, you'll find it works better after you've messed with all of them.  it just gets kinda confusing sometimes.
« Last Edit: November 20, 2006, 11:07:59 am by davieboynj »
Level42
« Reply #99 on: December 27, 2006, 06:02:14 pm »
Man it's been long, but what is the situation Kowal ? Have the ball tops arrived from Japan already ??
kowal
  • Suzo 4ever
« Reply #100 on: December 28, 2006, 07:19:14 am »
akihabara is inoperative 2-3 month all be annulled. It writes about problems  [urlhttp://forums.shoryuken.com/showthread.php?t=108982]here[/url] (last 5 sides). I do not know when this will become open again they do not accept orders
http://www.akihabarashop.com/status.html
I thought order from RS2006.  But only large orders accept there  >100000 jpn  near smaller orders is punishment +75$  :P
I do not know what to do. I can sell only handles, or from red balltop, or to wait until akihabara will come back.
  • Last login:Today at 03:22:36 pm
« Reply #101 on: May 03, 2009, 06:55:19 pm »
Hi, I'd like to know if it's still possible to purchase one of these custom made stainless sticks? I already have both Seimitsu and Sanwa balls, so I'm really only interested in one of these beautiful metal sticks.
Also I'm new here, and I say hello to you kind sirs.
Emph
specfire
  • Last login:April 23, 2016, 10:39:09 pm
  • Shhh...
« Reply #102 on: June 30, 2010, 10:31:01 pm »
sooo.............
I foolishly didn't buy a pair of these back four years ago.  Does anyone want to sell theirs?  Anyone else up to fabricating these again?  Franco B?
Read to your kids, you'll all be better for it.
lilshawn
  • Last login:Yesterday at 08:27:40 pm
« Reply #103 on: July 01, 2010, 01:20:25 am »
My brain hurts after reading that.
That...was...PAINFULL.
Though the post of ultimate deascription was not fully understand. If left to the persons of choosing by people. We have nothing left by choseing the people.
The post of ultimate description fail in the most abrupt way.
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #104 on: July 01, 2010, 07:20:18 am »
He doesn't speak English, but does great projects and research for the community.
Please just ignore it if it bothers you.  :cheers:
lilshawn
« Reply #105 on: July 02, 2010, 12:09:14 am »
sorry my eyes are bugging out... i had to read it three times to grasp what he was getting at. i think i have it now though. still i'm unsure about the joystick overall. seems a little overcomplicated for what it does.
Monty
  • Last login:June 17, 2014, 06:29:17 pm
Monty
